Running electricity to fireplace.
19K views 6 replies 3 participants last post by  chris75
I'm adding an outlet in the back of my fireplace for a fireplace insert. The easiest access for power is if I drill a hole in the brick in the basement and run the wire up through the ash door which is on the floor in the back of the fireplace.
I was planning on using a junction box over the hole that I drilled so that it looks like a cleaner installation. The wire will only pass through the j-box. It will look like a dead end but the wire will come out the back side of the j-box. EMT will be used between this junction box and the feed junction box with NM or bx running in the conduit. Would I need a fitting on the backside of the j-box?
Does this sound like a good plan?
The easier idea is to just run bx off the closest j-box and run through a hole in the chimeny and up and through the ash door. If I opt for this route, do I need to protect the wire at entry point (drilled hole) of the chimney?
TIA
Cliff
No need to protect a cable assembly coming through brick, in my opinion. You will definitely need a connector for your EMT coming out of the back of the JB. I am assuming ( can't see the fireplace set up ) that common sense in being applied here and none of the wiring is "in the line of fire:whistling2: " where it may get hot.
Andy
#4 ·
Thanks Andy,
If I need a connector in the back of the J-box that makes the hole I need about 1 1/4".
After some more thought, especially since I don't need to protect the cable as it goes through the brick, I'm going to just run bx through the hole and forget about the j-box on the brick. That will speed installation from an hour or two to about 5 minutes.
It's a gas fireplace and the electronics and fan are on the bottom with a plug to power it up coming out through the side. It shouldn't get that hot or it would self destruct.
