Running Electrical Wire/ethernet Alongside Natural Gas Line - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 04:37 PM   #1
running Electrical wire/ethernet alongside natural gas line
Hello!
I ran electrical and ethernet wire from the basement (4th level) to the 3rd level. On the 3rd level theres an I-beam that runs north to south, on the inside of the beam they ran the gas line to the fireplace, I decided to run the wires alongside considering the ease of running them in the 'dead space' of the i-beam. The natural gas line is insulated. Is this something I should be worried about?
Thanks in advance,
Max
running Electrical wire/ethernet alongside natural gas line-imag0514.jpg   running Electrical wire/ethernet alongside natural gas line-imag0509.jpg
lazzz is offline   Reply With Quote
Old 03-21-2013, 04:59 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
You will have more issues with the ethernet cable run close to the electrical cable than with the gas line.
Old 03-21-2013, 05:03 PM   #3
Thanks jb,
I did read about interference happening when high and low voltage are nearby, is this a fire hazard as well?
Old 03-21-2013, 05:18 PM   #4
Master Electrician
Rewards Points: 3,820
What gas line? Looks like an insulated water line to me.
brric is online now   Reply With Quote
Old 03-21-2013, 05:19 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No he won't... its twisted, he wont have any issues... I always share the same holes line voltage/low voltage.
Old 03-21-2013, 05:22 PM   #6
That line runs to the main gas shutoff.
Old 03-21-2013, 05:38 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You are tracing it out wrong. Nobody insulates a gas line.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (03-21-2013)
Old 03-21-2013, 05:50 PM   #8
jbfan's Avatar
Rewards Points: 386
Then, no issues at all!
The Following User Says Thank You to jbfan For This Useful Post:
Old 03-21-2013, 05:55 PM   #9
Rewards Points: 13,450
I have before, boss shows up with no flashlight and tells me to insulate all the pipes under the house in a crawl space.
I'm trying to do all this by feel in the dark.
Later when he comes back with a light I could see what I had done.
Old 03-21-2013, 06:37 PM   #10
And if it were a gas line... copper? Sounds dangerous.
chris_b is offline   Reply With Quote
Old 03-21-2013, 06:43 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
OMG.....the house is going to burn down..............................NOT
As noted....the bigger issue is proximity to the AC...but even then, the only real issue is if the jackets on both the AC and Cat 5(6) were nicked and you got ac on the Ethernet.
Ethernet is such a high freq that the 60hz AC line freq is not an issue. The twist in the Ethernet lines reduces any induced voltage and all Ethernet ports are transformer coupled.
Are you really sure that copper line is gas? That looks like a 1/2" copper water pipe....no reason to insulate gas. I don't 'think' there are safety issues using copper with gas...but, you might want to make sure.
Old 03-21-2013, 07:12 PM   #12
Rewards Points: 1,192
We still go by the old school cat cable rules. Stay away from fixtures, wires and other cables.
bobelectric is offline   Reply With Quote
Old 03-21-2013, 07:53 PM   #13
The line is natural gas, and it is copper... maybe builders do things differently in Canada? lol. (first copper pipe on the left)
Either way, I'm getting the feeling not to worry too much about it.
I appreciate all of the advice!
M
running Electrical wire/ethernet alongside natural gas line-imag0518.jpg
Old 03-21-2013, 11:22 PM   #14
Rewards Points: 506
Send a message via AIM to theatretch85
I'm no plumber but looks like whoever did the gas piping in that last pic doesn't know what they are doing. All those 90's and a gas line coming out the bottom down at the end, where does that go? All the sediment and crap in the gas lines is going to pour down into whatever is at the end. That's why T fittings are typically installed with a cap on the bottom where the sediment can collect.
Also, if it were me I would not run the network cabling in the same hole as the electrical. If its only for a short distance you'd probably be OK, but for any long distances you'll be sure to experience issues. Packet loss and intermittent connectivity and other "weird or unexplained" network issues are just some of the side effects. Where ever possible, you should always keep at least a 1' distance between the low voltage data cable and any electrical lines when run in parallel, and always cross at a perpendicular.
theatretch85 is offline   Reply With Quote
Old 03-22-2013, 12:17 AM   #15
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Usually my rule of thumb is, run electrical through holes in the joists made in the middle, and if going along a joist, keep the wire in the middle. Data is run under the joists. That way even if I need to run along an electrical wire they'll be about 6 inches apart give or take. Though I try to avoid it as much as I can but sometimes you can't.
I'm not sure about any codes related to gas lines but I would want to try to keep the line free, as free access may be needed when doing a leak check.
Need help on running gas line to detached garage gjones Plumbing 2 05-22-2012 06:30 AM
Running electrical to a new barn (Help Needed) Barnbuilder Electrical 20 02-18-2012 03:44 PM
Running a power line to a yurt cloudedwards Electrical 4 08-12-2011 10:46 PM
Natural gas line to garage SxS Plumbing 11 08-27-2010 06:08 PM
Running a natural gas line Roger General DIY Discussions 2 02-27-2009 07:42 AM
