Running Electrical Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2013, 02:55 PM   #1
Rewards Points: 396
running electrical wire
hi guys,
I need to run wire to a switch for an exhaust fan. Do you have any suggestions on the best way to locate the bottom plate of the bathroom wall so I can run the wire up through the wall?
detroittigerfan is offline   Reply With Quote
Old 11-25-2013, 03:58 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Look for things that go through that wall already and measure off those. For example is there any existing wiring or ducting there? Alternatively, measure off of an outside wall. Is there a reason you can't pull power from the switch or light already there and add a new switch in?
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
plummen (11-26-2013)
Old 11-25-2013, 04:32 PM   #3
Licensed electrician
Rewards Points: 996
You can also drill a small hole right at the baseboard and measure from there.
Old 11-25-2013, 04:39 PM   #4
DIY Enthusiast
sublime2's Avatar
This will do the job.
http://whatatool.myshopify.com/products/flexi-drill
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
gregzoll (11-26-2013)
Old 11-26-2013, 03:43 PM   #5
Rewards Points: 336
That looks like a horrible idea in most circumstances.
JKeefe is offline   Reply With Quote
Old 11-26-2013, 03:54 PM   #6
Rewards Points: 12,790
Why's that? It's done that way all the time. It also allows you to pull the wire back when you pull the bit back out of the wall.
Old 11-26-2013, 03:57 PM   #7
Rewards Points: 336
I like to see where I'm operating power tools. I understand that it isn't always 100% possible, but sticking a drill bit on a steel cable blind into a wall is asking for trouble in my mind. I'm no pro, so if the pros do it this way more power to them.
We're a bit off-topic, anyway. The question was how to find the bottom plate, not how to make a hole in it. The best way to drill it depends on how it can be accessed.
Old 11-26-2013, 04:08 PM   #8
Oso954's Avatar
Rewards Points: 386
If you do it blind you are doing it wrong. Use an inspection mirror and flashlight to clear the area first. Also inspect from below, before drilling.
Done correctly, it is as good or better than drilling up (blindly if you did not check inside the wall) based an measurements.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 11-26-2013, 05:46 PM   #9
Dave88LX's Avatar
Rewards Points: 564
Originally Posted by sublime2 View Post
Make sure you have a powerful drill using one of these. At least in my limited experience. Got stuck, couldn't get in or back out.
Dave88LX is offline   Reply With Quote
Old 11-26-2013, 05:57 PM   #10
DIY Enthusiast
sublime2's Avatar
Ah, he wants to locate the bottom plate to DRILL a hole through it to run cable!
Re read the OP.
Old 11-26-2013, 06:01 PM   #11
Rewards Points: 6,652
Flex bit and fish stick, is the way to properly do this.
The Following User Says Thank You to gregzoll For This Useful Post:
sublime2 (11-28-2013)
Old 11-26-2013, 07:16 PM   #12
DIY Enthusiast
sublime2's Avatar
Based on your comment,
You obviously don't do a lot of DIY work.
If you did you would know what you were looking at and know how to use it.
Electrical wire through and under patio pavers chuckp27 Electrical 6 04-10-2013 08:54 PM
Phone wire along side of electrical wiring DiegoJames Electrical 3 07-10-2012 10:23 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Can Electrical Wire go on the I-Beam thebrandnewguy Electrical 8 08-12-2011 11:16 PM
Low voltage wire & electrical wire (NM) dyang Electrical 3 05-04-2010 11:02 PM
