Running Electrical Out To The Garage... - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 07:34 PM   #1
Send a message via Yahoo to HomeBrewJeff
Running 220v outside through LB box.
Sorry for the question on the first post, but it is what it is I guess..
I'm looking to run a 220 / 50amp line (four 6AWG THWN wires buried 18" in 1.25" conduit) out to the garage. My question is regarding the proper method of exiting from the house. My plan was to use an LB fitting, but then I looked outside and found what might be a problem.
That cable just above the window is main line coming into the house. Originally I was planning on coming outside to the right of the window, but then realized my conduit (from the LB box) would actually come down in front of the main line.
The power meter is about 15' to the right of the window, so it would be a significantly larger job to exit on the right of the power meter.
Is this going to be a problem? Is it OK if my new line (albeit they will be inside the conduit) crosses the main line? Is it correct to assume the LB box should be ~18" above grade?
Thanks for your help!
HomeBrewJeff is offline   Reply With Quote
Old 05-21-2009, 08:06 PM   #2
Rewards Points: 2,350
I hate to see exposed SE cable like that! That sucks. Sorry for the rant. Anyway, shouldn't be a problem, just don't crush it or otherwise disturb it. BE VERY CAREFUL working around it. It probably wouldn't take very much to have it explode in your face.
Old 05-21-2009, 10:59 PM   #3
What he said ^
NEC actually still allows installations like this but then it's against code to sleeve a short piece of romex outside, under an eave, going to a floodlight.
Go figure.
220/221 is offline   Reply With Quote
Electrical problem in garage ginaca Electrical 10 04-19-2009 07:51 PM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 01:40 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
Subpanel Questions/Running electrical to garage. FlyGuy Electrical 28 05-24-2008 11:50 PM
running wire to detached garage amakarevic Electrical 2 02-28-2008 03:17 PM
