Running Electrical Into An Insulated Room - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 10:38 AM   #1
Running Electrical into an Insulated Room
Looking for advice regarding an unfinished insulated above-ground room that we're looking to finish off. This is a Ryan Homes Townhouse. The back half of the first floor has been unfinished since we purchased the home. As I already said the room is already insulated but there is no electrical. How do I run electrical to this room?
1. Put up a new frame over the frame with insulation and run electrical through that?
2. Try to run electrical through or over the insulation and use nail plates? Would that pass inspection?
3. Rip out insulation and start over?
Any advice is appreciated. Thank you.
I've attached a picture of what i'm looking at in the room.
Samwise2013 is offline   Reply With Quote
Old 06-15-2013, 10:45 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Pull permit...remove insulation...install electrical...rough inspection...reinstall insulation
Old 06-15-2013, 10:58 AM   #3
MarginallyQualified
Rewards Points: 2,464
Are you CERTAIN that the room doesn't already have some basic wiring?
A receptacle circuit and maybe a light?
Old 06-15-2013, 11:05 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Yea...that^^^............it would take you all of 5 min to pull back that insulation...and maybe 10 min to put it back.....and and 10 to fix what they didn't do right....
Get it all back to bare studs....a lot easier to work with....take plenty of pics for future use.....
And get those permits....it's easy....but will pay off in the long run.
Old 06-15-2013, 11:11 AM   #5
The only electrical in the room is a light running directly from the ceiling in the other room. The light is on the same circuit for the other room. While there appears to be a circuit dedicated to the room it stops in the adjacent room at a receptacle with a cover plate.
Old 06-15-2013, 11:12 AM   #6
Thank you all for your help. I had a feeling that was the answer. Just wanted to make sure.
Tags
insulation , rough-in
Running electrical through floor mihomeowner Electrical 29 08-02-2012 03:35 PM
Running electrical to a new barn (Help Needed) Barnbuilder Electrical 20 02-18-2012 04:44 PM
electrical run to guest room terryob Electrical 5 05-24-2011 06:58 PM
Help/Suggestions Running Cat5e Acroos Room To New Panel darveaux Electrical 6 02-28-2011 03:12 AM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 06:08 PM
