Running Electrical Home Runs - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 05:04 PM   #1
I am in the process of re-wiring a whole house I purchase and plan to live in. My question is can I run my home run wires from the second floor, down through the exterior wall? Will this be a problem with inspector or not a problem. Thanks in advance for any help or input.
POWER STROKE is offline   Reply With Quote
Old 09-30-2012, 05:22 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Not a code issue but it is more energy efficent to keep the outside wall for best insulation. I was taught to use the first stud bay next to the outside wall.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-30-2012, 08:25 PM   #3
thanks for the help and reply
Old 09-30-2012, 09:30 PM   #4
deverson's Avatar
Rewards Points: 77
You might have to derate the circuit depending how many wires you run up there.
deverson is offline   Reply With Quote
Old 09-30-2012, 11:27 PM   #5
Missouri Bound's Avatar
HUH?
Do you want it your way or the right way?
Old 10-01-2012, 07:01 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by jaydanadem View Post
you will need to enclose the exposed cabling within a weather proof ducting or conduit
for mechanical protection.
this is the correct procedure.
Paul, PFS Electrical NSW
www.pfselectrical.com.au
Another post with misinformation.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
jbfan (10-01-2012), OCPik4chu (10-02-2012)
Old 10-01-2012, 07:27 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
What has to be double insulated?
Running wires in an outside wall is fine and dandy.
Make sure you use proper wall insulating codes when you are done.
Running Network Cable in preexisting home Nate8727 Building & Construction 19 06-30-2011 03:27 PM
log home...electrical msauve Electrical 5 06-28-2011 12:20 PM
electrical requirements for large whole home system jumonji Electrical 6 02-23-2010 02:41 AM
running boards for electrical in unfinished basement paulyg Carpentry 2 01-26-2010 10:21 PM
Running new 2nd floor wiring on *exterior* of our home? drh Electrical 12 02-16-2008 07:27 PM
