Running Electrical In Furred Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 10:40 AM   #1
Running electrical in furred wall
I need to run some pretty basic electrical (a couple of plugs and a couple of switches) through a furred wall.
The existing wall is double wythe brick and I will be furring the lower 2/3rds of the wall using 2x3s on their sides, covered with wainscotting.
I am hoping to be able to use the slim, low profile electrical boxes, and I know that the cable needs to be protected. The house, and all of my work will be in romex, but I know romex cannot be run through conduit.
What do I do here? What type of cable can be run through conduit? Is it "compatible" with romex? Anything special I need to know about tying the conduit cable into the romex?
Thanks!
stubits is offline   Reply With Quote
Old 05-06-2010, 11:10 AM   #2
Just call me Andrew
Rewards Points: 1,020
I think it's ok to run romex inside conduit if it's large enough. See Dave's response in this thread:
Originally Posted by Scuba_Dave
As long as the conduit is sized large enough for the romex it is OK & meets code
(3) #12 THWN need 1/2" conduit
(1) 12-2 cable (.450") will also fit in 1/2" & meet code
But the 12-2 will be a PAIN to pull thru any distance
I sleeved 12-2 UF in ~8' of conduit to go into a storage area junction box
From there I went with THWN in the conduit
If you don't want to use cable, you can run individual THHN/THWN wires (red/white/green) inside conduit. If you go to HD or Lowe's, their individual strands of wire are dual-rated for THHN and THWN. Either of those classifications are fine for dry (indoor) use. May as well just use romex.
Andrew
secutanudu is offline   Reply With Quote
Old 05-06-2010, 10:02 PM   #3
Licensed electrician
Rewards Points: 1,888
3M makes a device called a Stak-it for furring strips to provide for the 1 1/4" standoff distance required for the furring strip.
Running romex along a wall in a closet Red Squirrel Electrical 16 10-02-2009 08:44 PM
how to find an electrical plug, covered up by a wall luckymen Electrical 15 07-07-2009 06:27 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 10:23 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 09:54 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
