Running Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 06:34 PM   #1
Running electrical
ran new wiring in our garage, went from one overlead light to two and outlet, relocated the wall switch also. When we flick the switch, first light comes on, and outlet works- get maybe half power , but notthing to the second light. , got any suggestions?
Ben Kuhlman is offline   Reply With Quote
Old 10-20-2010, 12:38 PM   #2
Rewards Points: 512
You need to reword this. "went from one overlead light to two and outlet, relocated the wall switch also."
Is this garage detached from the home or not? For what purposes are you wiring the garage, anything other than lighting and small handtool uses?
Old 10-20-2010, 12:59 PM   #3
More questions than answers Im afraid. You need to provide more info as sirsparksalot requested. How did you run the wire from house to garage if it is detached? Regarding the plugs are they used or new ones, if old they can possibly been used a a split recepticle. Are the plugs on the switch as well ??
More precise info and we can help you alot more
**FYE**
**FYE** is offline   Reply With Quote
Running electrical wire into 98 Buick Lasabre Red Squirrel Automotive Repairs 5 04-22-2010 09:08 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-08-2009 11:49 PM
running underground electrical, communication, and water Chavez Electrical 4 04-05-2009 12:45 PM
Electrical wiring running parellel and through ductwork? Beren Electrical 1 06-01-2007 04:08 PM
