Running Electric To A Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 10:46 PM   #1
Running electric to a detached garage
I need to run electric out to the garage all it has is one receptical outlet one light and an electric garage door. Can i run a wire out of the main breaker box in the house underground and right into the garage? and will i need a subpanel in the garage and how big?
xspader298 is offline   Reply With Quote
Old 03-19-2011, 10:58 PM   #2
liscenced electrician
Rewards Points: 538
depends on what you want to do. You could run 12-2 and just hook up a few receptacles and a light. Going through the effort, id run bigger wire and do a small sub panel
jimmy21 is offline   Reply With Quote
Old 03-20-2011, 11:48 AM   #3
Rewards Points: 58
Do a search on this forum. Plenty information.
Old 03-20-2011, 01:17 PM   #4
Rewards Points: 1,016
One of the more commonly asked questions here, using the search will find you much information directly related to your need. I suggest doing some researching and searching, if you have any remaining questions or need clarifiations just ask.
Old 03-21-2011, 09:46 AM   #5
V, A few things I've learned lately... if it is a single circuit from one breaker, you don't need a sub panel or grounding rods (easy)... judging from your stated needs it sounds like a single circuit would do... underground wire must be in a conduit unless it is rated UF (underground feeder)...you did not say how far but if it's less than 60' you will have negligible voltage drop...you must have a cut off switch in the garage (a regular light switch will do). Hope this helps.
Joe Willie is offline   Reply With Quote
need opinons on electric to a garage jerryinmich57 Electrical 2 01-29-2011 10:28 AM
correcting existing subpanel in detached garage mtk Electrical 17 03-14-2010 02:49 PM
60 amp sub panel for a detached garage canyonbc Electrical 32 01-11-2010 12:53 PM
ENT (Smurf) feeding a sub in detached garage) jamiedolan Electrical 1 02-02-2009 01:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
