Running Electical Plug Behind Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2007, 07:54 AM   #1
Running Electical plug behind wall
Can I run the electrical plug from my tv inside the wall (interior) and then have it exit somewhere near the baseboard? Are there any issues with running it behind the wall?
burdman is offline   Reply With Quote
Old 04-18-2007, 09:13 AM   #2
jproffer's Avatar
Rewards Points: 716
No you can't. But what you CAN do, and should do, is add a new receptacle downstream of the one (that I assume is) near where you were going to "exit" the wall.
Other than being a blatant code violation...yes there are, but there's no reason to go into it. It's a code violation, 'nuf said.
jproffer is offline   Reply With Quote
Old 04-20-2007, 10:15 AM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Are you trying to hang an lcd/plasma on the wall and hide the cords?
If so, best thing I've found is to get a clock receptacle and wire it behind the tv. The tv can plug right into it no problems and the clock receptacle gives enough clearance for the plug to sit behind the tv.
Clock receptacle is a basic receptacle that is recessed to fit a plug and its stubby end inside to allow clearance for a clock/tv...
J187 is offline   Reply With Quote
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 02:18 PM
Plug comes out of wall jackiesmom Electrical 2 05-30-2007 10:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
