Running DC Device Off AC - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 05:08 PM   #31
Rewards Points: 462
Originally Posted by bcgfdc3
jump start pack used for a car
Ah yes, but what we forget is that I'm looking for something cheap and no more than about 4 inches square.
I did pick up a 200V 10A bridge rectifier. Output voltage is 11.6V DC, however, under load it reduces to 8.3V. I don't know the amperage rating of the AC transformer but it's pretty beefy. However, I'm guessing it's not powerful enough.
Richo is offline   Reply With Quote
Old 07-25-2012, 05:48 PM   #32
Rewards Points: 266
You can sometimes pick up inexpensive parts at places like allelectronics and goldmine-electronics.
ionized is offline   Reply With Quote
Old 07-25-2012, 06:51 PM   #33
dmxtothemax's Avatar
Rewards Points: 5,096
Sounds like your tranny is not powerful enough !
go for bigger !
You will need something in the 5 to 10 amp range .
dmxtothemax is offline   Reply With Quote
Old 07-25-2012, 07:36 PM   #34
Rewards Points: 462
OK here's a possibly dumb question....
Can two 5A 12V AC transformers be connected in parallel for 10A?
This is the type of transformer I have
I have plenty of these laying around, some 6V, some 12V, some 24V.
Old 07-25-2012, 07:45 PM   #35
Rewards Points: 266
Some transformers can be connected in parallel by some people. You can not, however, connect anything that looks like that in parallel without very likely making smoke.
Old 07-26-2012, 05:21 AM   #36
You can !
But it is not considered good practice !
You must feed them both thru a large resistor
first before you parrallel them.
Use a 10watt .22 ohm resistor for both.
Do not try to connect them together with out these resistors.
The trannys must be the same in voltage and current for it to work.
A fuse before the resistor would be wise !
Old 07-26-2012, 08:57 AM   #37
Rewards Points: 462
Doesn't sound like that would work because these transformers vary in output voltage + or - about 1.5 volts.
I also thought about a 24V transformer using a household dimmer to dial down the input voltage until the output matches 12V, but that also sounds iffy to me.
This is more of an experiment than anything else, just to see if I can accomplish it with what I have laying around.
Old 07-26-2012, 10:55 AM   #38
Rewards Points: 266
Keep in mind the the nominal voltage for automotive power is way above 12V.
Old 07-26-2012, 11:02 AM   #39
Rewards Points: 462
He has been using some kind of monstrous power pack to run the light. I have to get a hold of that and see what kind of voltage it is putting out.
Old 07-26-2012, 11:36 AM   #40
Rewards Points: 3,256
11 to 14 volts or thereabouts would do ya good.
zappa is offline   Reply With Quote
Old 07-26-2012, 11:31 PM   #41
You should try using a large 10a automotive battery charger,
They are normally quite cheap !
Old 07-26-2012, 11:38 PM   #42
Electrical Contractor
kbsparky's Avatar
Just get one of those landscape lighting transformers and put the bridge rectifier on its output.
We use `em all the time for DC lighting projects ...
-KB
Old 07-27-2012, 12:19 AM   #43
Rewards Points: 462
Something like this and just pulling the guts out?
http://www.menards.com/main/outdoor/...614-c-6388.htm
We have an old battery charger somewhere in the clutter at work, I just have to find it to see what the amperage rating is on it. Looked around a little today and didn't see it but we have shelf loads of boxes
Old 07-27-2012, 12:49 AM   #44
JOATMON
ddawg16's Avatar
Rewards Points: 798
By a 12Vdc power supply.....here is one for $30
http://www.automationdirect.com/adc/...ies)/PSS24-100
ddawg16 is online now   Reply With Quote
Old 07-27-2012, 08:57 AM   #45
Rewards Points: 462
That one looks to be 24V but it says "adjustable". Does that mean one set of output terminals is 12V?
Otherwise there is this
http://www.automationdirect.com/adc/...s%29/PSS12-100
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 05:00 AM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 10:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
constant running water sound gmk2008 Plumbing 9 11-11-2008 09:22 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
