Running DC Device Off AC - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 03:02 PM   #16
Rewards Points: 462
Originally Posted by DangerMouse View Post
Of course, using full wattage will likely blind your audience, but I suppose that's part of the fun!
Certainly
So, do you think there would be a problem using something like this?
http://www.ebay.com/itm/LED-Strip-SM...item20c4f554d4
Richo is offline   Reply With Quote
Old 07-23-2012, 05:37 PM   #17
You have spec's on the transformer?
A diode bridge plus heatsink for this project can't be too much.
Old 07-23-2012, 05:46 PM   #18
Rewards Points: 462
No specs. Just found it online and wondered if it would be sufficient to run the light.
Diode bridge & heatsink? Are you referring to the power supply containing that or adding it afterward? Either way, that's a bit over my head.
Old 07-23-2012, 05:59 PM   #19
Rewards Points: 266
If you can replace the bulbs with LEDs, you can cut power consumption considerably.
ionized is offline   Reply With Quote
Old 07-23-2012, 06:03 PM   #20
Rewards Points: 462
LED came to mind but it's a proprietary bulb made only by the manufacturer of the light. It wouldn't hurt for me to check if they make an LED alternative lamp. All of their light bar sets are LED now.
Old 07-23-2012, 07:09 PM   #21
Rewards Points: 266
[QUOTE=Richo;972649 it's a proprietary bulb[/QUOTE]
Are you sure? I'd take it to a lighting supply shop and ask them if they can identify the lamp. You might find an online shop that will look at a picture that you send them or look it up based on the manufacturer. Of course, even if it is a generic, unless it is sold in relatively high volume, it is not likely to have LED retrofits available. Is this a Unity or Whelen product?
Old 07-23-2012, 07:16 PM   #22
Rewards Points: 462
It's a Whelen. They told me to check out their website for a Whelen dealer in my area that carries their products.
Had no luck removing the lamp. I asked them how to do it and they said to stick a flat blade screwdriver beneath the tab on the lamp and give a 1/4 twist. Did that and the tab snapped off
Old 07-23-2012, 07:19 PM   #23
dmxtothemax's Avatar
Rewards Points: 5,350
If you feed the AC voltage thru a diode bridge,
you will have an output that is more like dc,
its not perfect,
but it will happily run the beacon light and its motors.
NO PROBLEMS.
You can get diode bridges from most good electronic shops.
If it is a large amperage draw a heatsink might be required,
if it is only small a heatsink might not be needed.
dmxtothemax is offline   Reply With Quote
Old 07-23-2012, 08:18 PM   #24
Rewards Points: 462
Is a diode bride and a bridge rectifier 2 different things?
I do have a local electronics shop that may have what I need. I'll look into that.
Old 07-23-2012, 08:28 PM   #25
zpm
yeah, right
Don't make this harder than you need to. A typical PC power supply will put out 10A on the 12V rail. Plenty of info available on how to jumper them.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 07-23-2012, 08:37 PM   #26
Rewards Points: 462
Sounds easy enough but this power supply is going to be put inside of an enclosed box with no ventilation and a PC power supply gets pretty hot doesn't it?
Old 07-23-2012, 10:23 PM   #27
Rewards Points: 192
Smile
The easiest answer would be to pick up a lawn tractor battery or in the past I have used a jump start pack used for a car
bcgfdc3 is offline   Reply With Quote
The Following User Says Thank You to bcgfdc3 For This Useful Post:
DangerMouse (07-24-2012)
Old 07-24-2012, 12:16 AM   #28
They are the same things.
Make sure it has adequate current rating.
Old 07-24-2012, 01:15 AM   #29
Pc power supply has a fan. Mount it in the box and cut a hole to match. And one in the front or side for makeup air.
Or get a 12 v power supply from radio shack. They make (made?) them to power mobile radio gear from home.
Evstarr is offline   Reply With Quote
Old 07-24-2012, 05:58 AM   #30
the Musigician
DangerMouse's Avatar
Safest, fastest, easiest idea I've seen yet!
DM
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 04:00 AM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
constant running water sound gmk2008 Plumbing 9 11-11-2008 08:22 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
