Running Condiut Inquiry - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2011, 10:51 AM   #1
Running condiut inquiry
Hi,
Can anybody tell me if there are codes or rules of thumb that do not allow electrical cable inside conduit to run parallel,
IE ....(along side of and taking the same route)
as the natural gas line of a residence to get to its termination point?
jodejr is offline   Reply With Quote
Old 10-07-2011, 02:49 PM   #2
Code05's Avatar
Rewards Points: 1,104
Originally Posted by jodejr View Post
Hi,
Depends, define your install with a little more detail.
Code05 is offline   Reply With Quote
Old 10-07-2011, 03:10 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,990
No, and there would be no reason for such a rule. What's your concern?
mpoulton is offline   Reply With Quote
Old 10-07-2011, 03:31 PM   #4
No concern ,really. I just like making sure on most things. Didn't think it would matter whatsoever..but there is no harm in getting input from those with more knowledge on issues that could go in any direction.thanks.
Old 10-07-2011, 05:32 PM   #5
Code05's Avatar
Most utilities require a 3' separation.
Old 10-07-2011, 05:46 PM   #6
To be more specific...I am not talking about outside or underground. Still a 3 foot separation? This is planning the shortest route for a possible gas/LP generator purchase.
Old 10-07-2011, 05:54 PM   #7
Code05's Avatar
Probably not, what did your inspector say? Local amendments may apply.
Old 10-07-2011, 06:01 PM   #8
early planning stages...just gathering info. Thanks for the input.
Old 10-08-2011, 04:20 PM   #9
I assumed this was in a building, not the incoming utility trench.
Old 10-08-2011, 04:36 PM   #10
Correct assumption...INSIDE......basement.
Sound of Water Running in Pipes rpishotti Plumbing 4 12-06-2010 12:09 AM
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 09:00 PM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
