Running Coax From Attic To Room Below, Via Exterior Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2007, 12:32 PM   #1
Rewards Points: 150
Running coax from attic to room below, via exterior wall?
Hi there. I need to run a coax (TV) cable from the attic, where it is fed from a conduit in the basement utility room, across the attic, and down a wall into my master bedroom. However, the wall it needs to be located on is an exterior wall. The nearest partition wall is across the room and quite a perimiter distance from where we need the cable.
How difficult is it to feed a wire through the exterior wall via the attic? The roof is on a typical ~45* slope above that wall. I have an awesome cordless drill and have many bits, and also have extentions to my selection of shorter spade bits.
Any options?
curls00 is offline   Reply With Quote
Old 08-14-2007, 03:09 PM   #2
here is what i would do....a good framer will nail over stud only..this will help you locate the area to drill..(right angle drill is most helpful). do the math with a measuring tape. drill your top plate..you will be adding a remodel box for your coaxial outlet. (typically most people can reach inside this opening)
use a rigid fish to first locate, then you should be able to pull the cable on through...since there is no danger of electrical shock...i give this a 2 beer rating..
Tony Cunningham is offline   Reply With Quote
Old 08-14-2007, 03:53 PM   #3
Rewards Points: 150
Well I just peeked inside the attic and it look like a job for a helper monkey. Literally. The roof is pitched fairly flat in the area we want to drill, thus, there's almost no room at all for even a right-angle drill. Plus I used a stud finder on the wall we want to come down, and there seems to be a brace between studs about 3' or 4' above the floor level. So that would be a b1tch to get through as well. I think we may run down an interior wall if possible (found cross-bracing there too... wtf?), and then around the baseboards to the location we desire. It pains me to say that, though, as I really wanted a completely hidden drop to this bedroom.
*curse the original owner for specifically requesting NO coax in the master bedroom! Argh!
Old 08-14-2007, 03:54 PM   #4
how about all those insulation crab the fish line need to go through... would that be a problem... I done the same on interior wall before and really no problem... but external.... I am not so sure...
KUIPORNG is offline   Reply With Quote
Old 08-14-2007, 04:47 PM   #5
OKAY!!! heres the dill pickle....you have fire blocking...JEEZ!!!! do you have a friend that does drywall and finishing?
Old 08-14-2007, 04:50 PM   #6
do you have a crawl space
Old 08-14-2007, 04:52 PM   #7
Rewards Points: 150
Fire blocking, yes. Drywall friend? No. And we JUST painted last week so I'm not going there w/ the wife... LOL!
Basement, yes, but that's 2 floors down from this room.
Old 08-14-2007, 05:03 PM   #8
what kind of siding to the exterior do you have
Old 08-14-2007, 06:44 PM   #9
Rewards Points: 150
Vinyl.
Edit: I looked to my left (from my office to the exterior wall in question) and it's brick in that area. Booo.
Old 08-15-2007, 09:35 AM   #10
sound's like you need to buy those expensive 6 feet long drill bit to do this one time drilling job....assume you welling to spend that money...but what if you run into a live wire when doing down? may need advice from a pro how they do this...
Old 08-15-2007, 11:49 AM   #11
Rewards Points: 150
Well that "pro" is my dad, a master electrician. He won't be visiting me until next week (he lives in another city) but based on what I said, and the fact we both don't want to have to drywall a freshly painted wall, we might bring it down in the walk-in closet, go through the partition wall and then around the perimiter of the room to the desired location. Here's hoping I can get the RG6 between the baseboard and carpet w/o having to take off the baseboards (MDF crap that will likely break instead of come off nicely).
Old 08-15-2007, 12:36 PM   #12
why not wait one more week for your Dad to hear what he has to say then.... there are other things you can do in a bedroom besides watching TV...
Old 08-15-2007, 01:14 PM   #13
Rewards Points: 150
By "We" I meant my dad and I.
The other "We" (wife and I) have plenty of "non-tv" activities to keep us occupied until then. Like caring for our 15-month old. LOL!
Old 08-15-2007, 02:18 PM   #14
I see... RG6 between baseboard and carpet is going to be tough not to be visible or got loosen up... if you are a perfect seeker... you probably need to install new baseboards...
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 07:36 AM
Running New Coax modena Home Theater 3 07-18-2007 01:18 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 04:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 05:08 PM
