Running Cat6 And Romex In Same Holes - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 07:11 PM   #1
Running Cat6 and romex in same holes
I'm getting ready to run cat6 and romex through new framing. It is my understanding that they can be ran through the same stud holes, parallel with each other, and that the NEC does not require a separation if NM cable is used. I just want to verify that this is accurate. I understand it's probably not best practice, but if it's legal, then that's all I care about right now.
Thanks.
Tonglebeak is offline   Reply With Quote
Old 07-14-2013, 09:20 PM   #2
Bill Kearney
Rewards Points: 1,174
You need separation between them otherwise you end up with line noise that wrecks being able to use the CAT6 cabling. You'd be better off not installing it than doing it that way.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
MTN REMODEL LLC (07-15-2013)
Old 07-15-2013, 03:24 AM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
Running low voltage and Electric Light & Power circuits in the same hole as you describe is not permissible by the NEC. I don't have my code book in front of me, but I believe the requirement is a minimum separation of 6".
Not to mention the amount of interference you'd get by doing the cabling this way, especially if the romex circuit has a motor or a high draw load on the other end. Depending on the circuit, the path and how long they are together for, I'd be surprised if you get a better connection than wireless.
Bottom line, drill a new hole and do yourself a favor and make it a minimum of 12" away.
theatretch85 is offline   Reply With Quote
Old 07-15-2013, 05:51 AM   #4
Rewards Points: 166
Originally Posted by theatretch85
Running low voltage and Electric Light & Power circuits in the same hole as you describe is not permissible by the NEC...
I'm no expert on the NEC, but I'm pretty sure this is wrong. There may be a problem with putting them in the same raceway or terminating in the same box because of differences in insulation, but holes through studs are not a raceway. Of course your inspector will be the final word on this.
That said, it's a bad idea for interference reasons. You can put data cables close to higher voltage cables for short distances with no problems, but running them parallel for longer distances can theoretically introduce noise. This is especially true if someone plugs an electric motor into your circuit. Some people claim this can be mitigated by putting a gentle twist in the romex every few feet.
CAT5e/CAT6 cables are twisted pair cables designed to handle some electromagnetic interference and anyone who works with data networks in commercial environments will tell you they see un-shielded data cables run next to high voltage cables all the time with no apparent ill effect. Still, in a residential setting with new framing its pretty easy to just avoid the whole problem by running them separate.
Reference "300.3(C) Conductors of Different Systems"
dftc is offline   Reply With Quote
Old 07-15-2013, 01:47 PM   #5
Licensed electrician
Rewards Points: 1,272
DFTC is correct. Through the same hole is not an NEC issue.
Old 07-15-2013, 02:32 PM   #6
Bill Kearney
This.
It'd be worth putting the question to the permitting office. You don't want your permit delayed trying to squabble over what is or isn't "allowed" by code.
Old 07-15-2013, 05:36 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Its fine to run low voltage and high voltage cables in the same drilled holes, only audio fanatics freak out about this without justified cause, the twisting of the Cat5,6 eliminates any unwanted line noise. it's a moot point.
Old 07-15-2013, 05:36 PM   #8
E2 Electrician
Originally Posted by wkearney99 View Post
This.
Why? the NEC is pretty clear on it.
Old 07-15-2013, 08:04 PM   #9
Bill Kearney
What the NEC might say vs how local inspectors interpret things is an age-old problem. Made worse, perhaps, when there's DIY labor involved. This doesn't make it right, but arguing with inspectors wouldn't get the permit issued any faster. Combine that with the likelihood for disrupting the networking on the line and it doesn't make much sense to go that route.
Or is there some other issue at hand here that's affecting being able to run the wires properly?
Old 07-15-2013, 08:07 PM   #10
Bill Kearney
And you know this based on what? Experience with line voltage gear or gigabit networking performance?
Having overseen and consulted on literally tens of thousands of network ports over several decades I'll err on the side of caution when it comes to avoiding interference with network cabling. I've had clients have to spend a fair bit of money to move the line voltage wiring because someone else 'assumed' it wouldn't be a problem. And it wasn't for most of the year... until the AC gear powered on that circuit kicked in and disrupted a considerable number of workstation's networking.
But hey, feel free to screw it up any way you choose.
Old 07-15-2013, 08:08 PM   #11
E2 Electrician
Personally, if inspectors actually read the NEC, it would be fantastic, if they want to call a violation, then they should post the section that was violated since the NEC is a permissive document, if you just agree to everything the inspector wants, that is just insane. And I never said argue, just ask for the code section that was violated, pretty simple.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Jim Port (07-15-2013)
Old 07-15-2013, 08:12 PM   #12
Bill Kearney
Get the inspection done and move on. Or get your shorts all bunched up on the annoying ways inspectors fixate on the wrong issues. The former sure seems like a simpler and easier way to move a project forward... the latter seems insane.
Old 07-15-2013, 08:33 PM   #13
Use the violation as a teaching moment, not a start of a heated dispute. Inspectors are human and will make mistakes. Once they tell you what they think you did ask them to read it and discuss it. The code doesn't always say what you think it does.
stickboy1375 (07-15-2013)
Old 07-15-2013, 10:17 PM   #14
E2 Electrician
That logic is insane, you would not agree if you were a contractor and it cost you money, if you bid a hotel with 100 rooms, and the inspector required a $10 dollar GFCI in every room that wasn't required, would you abide with the same attitude? I seriously doubt it. How about 200 rooms, still not convinced?
Old 07-15-2013, 10:21 PM   #15
E2 Electrician
Please, you have no documentation on this, its all an audiophiles wet dream... Keep selling moster cable while you are at it, because it IS the best....
