Running Cable For New Cieling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 11:58 AM   #1
Running Cable for new Cieling Fan
It appears that before I can being doing my basement, I must finish some outstanding projects. My wife wishes to have me install new ceiling fans were none exist. I wish to check my procedure:
I can tap into an existing outlet just below were I wish to put the ceiling fan switch. I ran a check and still have able room for wattage for the light/fan. From tap in in the outlet I am running a 14/2 cable to the switch, form the switch up to thru ceiling to the ceiling fan I am gonna run 14/3 (switch will be a fan/light switch.)
Am I correct I can run 14/2 to the switch then 14/3 to the fan?
Thanks.
Retirement is offline   Reply With Quote
Old 02-27-2009, 12:02 PM   #2
Yes, thats ok, it will work. Also, is the circuit 20 amp? If it is, you cannot use 14/2 and 14/3 and must use 12/2 and 12/3.
I would use a metal fan box and secure it with a fan rated bracket or put in a 2x4.
rgsgww is offline   Reply With Quote
Old 02-27-2009, 12:47 PM   #3
15 amp. I double check that to be sure. If I am correct I can have 1,440 watts for the 15 amp circuit (maximum). There are 2 small bedrooms, a closet and the hallway on the circuit I wish to tap. If I did every thing correctly I believe I under 1,200 on that circuit at any given time (including running a vacuum).
Thank you for the advice. Always makes me feel better when working with electricity.
Old 02-27-2009, 01:15 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
15 amp branch circuits that serve multiple receptacles and lights can provide 1800 watts not 1440. 1440 is 80% ...it is only calculated at that figure in residential if the load is a continuous load like a storage hot water heater or fixed in place heating.
For general purpose branch circuits serving lights and receptacles it is recommended that no load over 80% (1440 watts or 12 amps for a 15 amp branch circuit) of the branch circuit is plugged into any one outlet at a given time. But you can use the 1800 watts for your load calculations due to diversity of not all loads being on at the same time.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
Basic cable running question epeterson777 Electrical 14 02-07-2009 07:33 AM
Running RG6 Cable leted_82 Electrical 3 01-29-2008 07:16 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Running CATV cable tima2381 Remodeling 4 03-27-2007 11:17 AM
