Running Cable To A Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 09:50 PM   #1
Running cable to a detached garage
I was wondering the right way to run television cable from my house to my detached garage. Please help.
Kastern is offline   Reply With Quote
Old 10-04-2011, 10:24 PM   #2
Electrical Contractor
kbsparky's Avatar
Underground
-KB
Old 10-04-2011, 10:49 PM   #3
43 years in construction
Arkitexas's Avatar
You can run it overhead or underground. TV cable is low voltage so its installation is not as restricted as line voltage lines (over 70 volts).
On residential property exposed overhead runs should be at least 12' high (at the lowest sag) where vehicles travel or no lower than 10' at pedestrian areas (local codes may vary). Tie it to strain reliefs at the wall/roof and enter the building with a sag to prevent rainwater from running along the wire to the wall penetration. Use cable rated for exterior exposure. If the span is more than 20' a reinforced coax may be needed to prevent stretching.
Underground should be run in a 3/4" watertight PVC conduit with long sweep bends. Bury at least 12" below grade (check your local codes for greater depth). Turn the conduit up well above grade at the ends and waterproof/bugproof the cable exits.
In either case, minimize or eliminate splitters, splices, or other connections outside.
Rick
Arkitexas is offline   Reply With Quote
Old 10-05-2011, 07:17 AM   #4
Licensed electrician
Rewards Points: 1,774
Any conduit underground will get water into it. Flooded RG6 is the cable type needed for underground.
Code05 (10-05-2011)
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 06:52 PM
Running Sky+ cable bookersbeauty Electrical 1 04-09-2009 07:12 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
