Running All Black Wires Then Labeling Color At Terminals? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 02:15 PM   #1
DIYer
Rewards Points: 93
Running all black wires then labeling color at terminals?
Is it kosher to run, for instance, four black single conductor wires then appropriately color them with tape at the terminal ends?
Obviously running the appropriate color wire would be best but I ask only because I'm being given a giant spool of black 4awg copper and want to utilize it for a 4 conductor 240V run I need
dwoloz is offline   Reply With Quote
Old 06-18-2011, 02:20 PM   #2
Electrical Contractor
kbsparky's Avatar
Perfectly legal and acceptable, using #4.
...er ... as long as it's properly installed in some sort of conduit/raceway system....
-KB
Old 06-18-2011, 04:25 PM   #3
DIYer
Rewards Points: 93
Saweet
Thanks!
Old 06-19-2011, 12:38 AM   #4
" Euro " electrician
frenchelectrican's Avatar
That is not a issue as long it is bigger than 16mm˛ ( 6 AWG ) and have proper colour tape as well.
If you going to run this to subpanel just make sure you keep the netural and ground seperated { you may end up get a new ground bussbar that is only couple Euros. }
Merci.
Marc
Running speaker wires... MT Stringer Home Theater 9 01-18-2009 08:26 PM
wires under or beside a crawl running board? rtoni Electrical 7 09-17-2008 03:53 PM
running wires in a conduit analogmusicman Electrical 50 07-13-2008 08:49 AM
Running wires in corners mt232 Electrical 13 04-10-2007 09:21 PM
Running wires mt232 Electrical 4 03-22-2007 08:02 AM
