Running AC Unit Off Generator - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 07:37 PM   #31
Rewards Points: 150
Mrrh.
Plug it in. Turn it on and pay attention. Nothing's going to blow up in 10 seconds, and that's about how long it will take you to know if it's going to work or not. Turn it on. Your generator RPM will drop real quick and then hopefully come back up. It either will or it won't, or the breaker will trip. Those are your options. It won't burst into flames and it won't fry anything.
I have never seen anyone come up with so many reasons to reject answers in my entire life.
Manufacturers are *REQUIRED* to include a rating plate on their appliances, and one of the standard fields is AMPS. It's on there, you're just refusing to look for it, or telling us it's not there to inspire further discussion on it.
This does NOT need to be a long or difficult thread.
emolatur is offline   Reply With Quote
The Following User Says Thank You to emolatur For This Useful Post:
mpoulton (08-18-2012)
Old 08-17-2012, 10:25 PM   #32
Rewards Points: 850
well i looked it up and it says 6.5 amps / 220 volts. true, try it and see.
hotrod351 is offline   Reply With Quote
Old 08-18-2012, 12:18 PM   #33
Rewards Points: 850
well i came across a estate sale, tons of wire in different sizes. picked up some construction extension cords, you know the big heavy ones. put my 220 twist lock on one end and a 220 20amp outlet on the other. plug the 16000 btus ac in and it purred like a kitten. i know the 12/3 cable is enough but also picked up some 16/3 cable. going to check if it will work. the 16/3 isnt solid wires. anyway it works. no more sitting around with the tv and lights on in 120 degree temps and no ac. life is good.
Old 08-19-2012, 12:31 PM   #34
Rewards Points: 266
I'd pass on the 16/3. What are you thinking?
ionized is offline   Reply With Quote
Old 08-19-2012, 04:24 PM   #35
Semi-Pro Electro-Geek
Rewards Points: 2,922
16/3 on a 30A generator breaker is definitely unsafe. Why would you want to do this?
mpoulton is offline   Reply With Quote
Old 08-19-2012, 04:48 PM   #36
raylo32's Avatar
Rewards Points: 1,254
I think he wants this to be the thread that wouldn't die? He can't be serious... I hope.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 08-19-2012, 05:12 PM   #37
Rewards Points: 850
did the 12/3. done deal. finny.
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
Running a portable generator 150' away from the house mrbillz Electrical 11 09-27-2011 09:51 AM
Trane condensing unit keeps running fastback4 HVAC 1 06-08-2010 06:49 PM
York AC unit running slow...Please help :^( mr.coinring HVAC 52 05-29-2010 04:41 AM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 05:35 PM
