Running AC Unit Off Generator - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 09:00 PM   #16
Originally Posted by hotrod351 View Post
youve got it biggles, problem is finding out the amp draw. its not listed on the unit or in the owners manual, strange. but seeing as my 220 volt on my generator is only 30 amp. as for the worse case = burn out something in the ac. seeing as the unit is running off 2 = 20 amp breakers and the generator has a 220 thats only 30 amps, well thats a little short, if it had a 40 amp out then id give it a try. otherwise im going to have to continue to try and find out the amp pull, loaded and unloaded, of my ac unit. i do have one of those meters that clamp around the cable, maybe it will tell me the amps, when running and when the compressor kicks on, to make sure it doesnt exceed the output of the generator. to rig it up the way i want, electrical box and switch and wire, will cost a few bucks and dont want to waste money on something just to find out it doesnt work. i searched the internet to find the specs on the ac but nothing, other than the BTUs and voltage.
You should be able to run one. AC is running on a 20 amp breaker and generator has a 30 amp breaker.
M Engineer is offline   Reply With Quote
Old 08-14-2012, 09:02 PM   #17
I can see that you are definitely not an electrical engineer.
Venter is offline   Reply With Quote
Old 08-14-2012, 09:04 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Ugh, where do these guys come from?
Old 08-14-2012, 09:07 PM   #19
No. I am not. If the AC is run off a 20 amp 220volt breaker now why would it not run off a 30 amp 220 volt generator?
Old 08-14-2012, 09:10 PM   #20
E2 Electrician
Ugh... Really?
Old 08-14-2012, 09:12 PM   #21
First of all the receptacle size on the generator does not guarantee that the generator could actually provide that much power.
Second, a motor requires a lot of current when starting up. The generator can only provide limited surge power. The power company can provide a lot more.
Old 08-14-2012, 09:23 PM   #22
I thought he said the generator was rated at 30 amps at 220 volts and a surge rating of 8550 watts.
Old 08-14-2012, 09:25 PM   #23
dmxtothemax's Avatar
Rewards Points: 5,098
Yes it will provide enough running current !
But will it cope with the starting current ?
Most old gennys will !
But the newer ones might not !
So the answer is this !
That genny will run one A/C unit, provided it has enough capacity for the start -up !
Like I said, most of the older gennys will cope ok with SHORT TERM overloads.
But some of the newer genny might not !
You would be pushing your luck tring to run two A/C units.
So I would not reccommend that !
Give it a try and see what happens, it wont hurt anything !
dmxtothemax is offline   Reply With Quote
Old 08-14-2012, 09:28 PM   #24
I thought he said the generator was rated at 30 amps at 220 volts.
Your post said he could do it because the generator had a 30 amp breaker. That rationale doesn't work.
As for what the generator is rated for, the answer is 5,500 watts.
Old 08-15-2012, 07:43 AM   #25
Rewards Points: 850
first off my only intention would be to run one of my 220 ac units on a generator, by itself. and just because the generator says it has a 8550 surge doesnt really mean it has that. had a friend that was a electrical contractor but he died years back. dont know why they dont list the amp draw on the owners manual.
hotrod351 is offline   Reply With Quote
Old 08-15-2012, 08:48 AM   #26
raylo32's Avatar
Rewards Points: 1,226
Way to much hand wringing and discussion here... you almost certainly will be able to run one of them unless the a/c or generator is not working correctly. Just do like Stickboy says and try it.
BTW, you said you don't lose power for days at a time? I can tell you don't live in an area served by PEPCO. Most of our outages here do indeed last for days.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-15-2012, 09:44 AM   #27
Rewards Points: 266
[QUOTE=hotrod351;988771... i always have a couple of 5 gallon bottles that have some in them. ...[/QUOTE]
Have you figured out how long that will run the generator? I think that will be discouraging.
ionized is offline   Reply With Quote
Old 08-15-2012, 10:08 AM   #28
Rewards Points: 266
The short answer is yes, you will be able to run one of those AC with your generator. Unless the gen is way cheap and actually produces less than half it rated output it will be fine.
If it is a robust model gen, you might be able to run both. That will depend somewhat on how efficient the ACs are. You will want to start the one that draws more start up current first, and then start the one with lower start up demand. Your clamp meter will be handy to determine this.
Old 08-17-2012, 07:18 PM   #29
Rewards Points: 850
well i bought another 5500 watt with a 8250 watt surge, building up the courage to test it out, i have a 16000 btu backup ac i hardly ever use to try it on. think i understand what your saying, the generator might have a 8200 watt surge but for how long, im not sure how long it will have to feed it until it settles down. but im sure if can run the 16000 then it will be more than able to handle the smaller unit. it just would be nice in the summer, when its 110 + and humid, to be able to get some comfort. i had a friend that was a electrical contractor, died about 6 months ago, and he said theres nothing like the power from the electric company, unless you happen to have one of those $5000.00 OR $6000.00 units, they even have battery backup systems that will handle but now were really talking money. if i had that much money i dont think id live in a place where the temps get to 125+, at least not in the summer.
Old 08-17-2012, 08:29 PM   #30
Rewards Points: 850
according to this im good to go.
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
Running a portable generator 150' away from the house mrbillz Electrical 11 09-27-2011 10:51 AM
Trane condensing unit keeps running fastback4 HVAC 1 06-08-2010 07:49 PM
York AC unit running slow...Please help :^( mr.coinring HVAC 52 05-29-2010 05:41 AM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 06:35 PM
