Running A 60 Amp Panel From A Detached Garage 75 Feet Away - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 02:18 PM   #1
Running a 60 amp panel from a detached garage 75 feet away
I Whant to install a sub panel in a garage thats detached from a house 75 feet away . I whant a 60 amp subpanel coming from a 100 amp service whats the allowable volt drop ? also do i have to run it in conduit undergrond and whats the hight when i come up in the house is there a code that says how high i can run it up the side of the house. and how far away does the sub panel have to be form windows or doors and how high off the floor and what size plywood would i have to mount it two. also whant to run teck cable so i was woundring if i would need to put that in conduit or not
and when i come up the walls can i use pvc or does it have to be conduit
joshua67 is offline   Reply With Quote
Old 04-09-2011, 02:33 PM   #2
Rewards Points: 1,016
This is a very often asked question here - suggest to use the search function and you'll find a wealth of information. With info here and the great help from members I installed a 100amp subpanel in my detached workshop fed by a 60 amp breaker in the main box - with a run of nearly 100' between.
Old 04-09-2011, 08:54 PM   #3
Rewards Points: 1,418
For 75 feet you don't need to allow for voltage drop, just use the normal wire size guidelines. For 60 amps it would be 6 gauge copper (the required 4'th wire for the ground would be 10 gauge if you strung individual conductors in conduit).
Use direct burial cable 18 inches deep or conduit buried at least 6 inches deep.
Old 04-09-2011, 11:24 PM   #4
Missouri Bound's Avatar
Here's a calculator I use from time to time.....www.csgnetwork.com/wiresizecalc
Old 04-10-2011, 05:14 AM   #5
I am in SoCal and here is a recap of my detached workshop electrical installation:
  • 100 amp GE subpanel in newly constructed detached workshop (24'x30')
  • the 100 amp breaker in the subpanel serves as the disconnect
  • 60 amp breaker in main panel
  • THWN wire
  • 2 hots - black #6
  • 1 nuetral - white #6
  • 1 ground - green #10
  • ~100' run of 1.5" conduit with two 90 degree sweeps, buried 18"
Subpanel installed between studs - in the middle of an an open studded wall (so I didn't know/care what clearance requirements are - but a search here will find where someone has stated such I am sure). The height is at about my chest level. Entry to the workshop is via an LB about 12" up the wall, directly below the subpanel. Entry to the house panel is similar.
The nuetral and ground in the subpanel are not connected. The ground in the subpanel is connected to a ufer in the concrete slab.
The workshop has 220v outlets for a MIG welder, air compressor, and heater, several 120v outlets for general use and power tools, ample lighting, and a 30 amp RV outlet.
Everything works great - and thanks to all here that helped with advice and comments along the way.
Old 04-11-2011, 12:33 AM   #6
Scared Electrician
Saturday Cowboy's Avatar
I believe your burial depths to be wrong. It's 24" for cable and 18" for conduit.
NEC 300.5
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-11-2011, 02:32 PM   #7
NEC 300.5
Yup, that's why in my installation example the conduit is at 18".
Need help planning an electrical service upgrade to detached garage PaulTurner Electrical 2 04-05-2011 04:43 PM
Running from outside service panel into basement ksl420 Electrical 0 03-21-2011 12:30 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 12:44 PM
Electrical in detached garage mattjub Electrical 6 04-07-2010 11:44 AM
How to install sub panel in detached garage 70' away MEC Electrical 5 02-09-2009 06:31 PM
