Running #6 Wire ? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2009, 07:36 PM   #1
Solutions (handyman)
Rewards Points: 362
I am running #6 wire from a service panel to a (future) range in a porch/addition
Can I run the wire up and along the roof trusses or should it go through the walls?
If it should go through the walls (studs), is there a limit as to number of holes drilled through the studs?
I have two 3/4" about three feet apart and am just curious about the strength aspect.
Thanks, Mark
Mark Harvey is offline   Reply With Quote
Old 12-09-2009, 06:30 PM   #2
Mark - I copied this from the PM you sent
What kind of wire are you using ? In conduit, cable ?
Old 12-09-2009, 06:59 PM   #3
Rewards Points: 362
wire is #6 cable not in conduit. Non-armor
Old 12-09-2009, 07:16 PM   #4
IBEW#363 I am a Rat
Send a message via AIM to thekoolcody
It has to be armored or in conduit. I do more commercial then residential but, i dont believe you can run that threw the wall without conduit/armored cable.
thekoolcody is offline   Reply With Quote
Old 12-09-2009, 07:33 PM   #5
Cable does not have to protected (armor/conduit) in a wall
If its closer then 1.25" (?) to the edge of the stud THEN a nail plate to protect it where it goes thru the stud must be installed
I'd run it up above the rafters then back down
I'd rather not have #6 cable in a wall
I'm assuming the porch addition is enclosed & weather proof ?
Old 12-09-2009, 07:35 PM   #6
Rewards Points: 362
Thanks.
Old 12-09-2009, 07:39 PM   #7
Rewards Points: 362
Correct Dave. I'd prefer to go under the floor, but this isn't possible. My next choice is up and over. Just wanted another opinion. any additional suggestions are apreciated.
MARK
Running Under ground wire Robbro137 Electrical 1 08-21-2009 06:11 PM
What is the best way to wire this? RST Electrical 8 08-19-2009 12:29 AM
wire running question ponch37300 Electrical 4 04-21-2009 04:58 PM
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
running wire. wjlundyjr Electrical 4 08-12-2008 09:09 AM
