Running 50 Amp 250 Volt Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 04:29 PM   #1
Hey Everyone,
I'm running a 50 amp 250 volt circuit to my garage and want to have 2 outlets in it. One outlet in my ceiling for a car lift, and another outlet in the wall so that I can plug an arc welder or plasma cutter into it. The car lift requires a 20 amp circuit, and the welder/plasma cutter needs a 50 amp circuit. The car lift and the welder/plasma cutter will never be used at the same time.
I had a few questions.
1. Can i use 6/2 wire since neither the car lift or welder use a 4 wire hookup?
2. I want to run the 6/2 wire from the panel to the ceiling receptacle, and then down to the wall receptacle. Since these 250 Volt receptacles are not like regular wall outlets with 2 sets of lugs, how do I connect to the 1st receptacle in the ceiling, and then continue the wire down the wall? Do I need some sort of special box or connectors, or can I just use a regular junction box and twist the wires together with pigtails for the ceiling outlet? This would mean that I would need to use wire nuts that could accomodate three 6 guage wires in each bundle, and I can't even find a wire nut that would accomodate three 6 guage wires.
Any feedback would be greatly appreciated. This will be inspected, so I need to do it right.
Thanks!
451stroker is offline   Reply With Quote
Old 12-07-2011, 04:51 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Can I ask why you can't just run two proper circuits?
The Following User Says Thank You to Speedy Petey For This Useful Post:
darren (12-07-2011)
Old 12-07-2011, 04:58 PM   #3
Rewards Points: 1,418
Check the lift to see what the maximum ampere circuit rating is for it. (The power plug will give this away, for example if the power plug is for 30 amps (@ 240 volts) then you may not add a 30 amp receptacle and plug into a 50 amp circuit). Rather you will need a subpanel for the 50 amp garage feed with a 30 amp (double wide 240 volt) breaker, or a separate 30 amp circuit for the lift all the way from the main panel out to the garage.
Old 12-07-2011, 05:18 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,.... Run it to a Sub-panel in the garage, Then on to the outlets...
Old 12-07-2011, 06:40 PM   #5
I don't have the lift yet. I'm trying to get everything wired for the future so I can get it inspected and sheetrocked. The lift I'm getting has the following specs:
Voltage: 220v / 20a / 1ph
As far as I know, the lift doesn't come with any cord and is supposed to be hard-wired to a junction box. I wanted to put a cord with a twist end on it so that it can be easily disconnected.
The only reason I wanted to put both outlets on one circuit is to save space in my main panel and maybe a little work. The garage is already wired for lights and wall outlets on three 20 amp, 125 volt circuits going straight into the main panel. It's an attached garage and the main panel for the house is on the other side of the ajoining wall.
Would separate 250 volt circuits for the lift and welder be the preferred way to go?
If I did use a subpanel, what amperage should it be. I would be hooking up one 50 amp, 250 volt circuit for the welder, one 20 amp, 250 volt circuit for the lift, and another 20 amp, 250 volt circuit for a future air conditioner.
Is the subpanel overkill considering how close my main panel is to the house?
Thanks again!
Old 12-07-2011, 06:50 PM   #6
Sfeyelectric's Avatar
Thanks again!
Is this in attached garage?
Sfeyelectric is offline   Reply With Quote
Old 12-07-2011, 06:52 PM   #7
IMO no since it'll save your space in the main panel and allow you local access to the breakers.
I'd run 6/3 and use a 60A feeder breaker.
Old 12-07-2011, 08:03 PM   #8
The garage is attached. I technically do have room on my main panel, since most of the house's original circuits are on a 100 amp sub panel already (I had the service moved so that I could build the garage).
Old 12-07-2011, 08:10 PM   #9
Master Electrician
Rewards Points: 3,678
So.........I can't plug a 240 volt 15 amp air conditioner into a 240 volt 20 amp circuit?
brric is offline   Reply With Quote
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
30 amp 240 volt circuit blaste Electrical 6 07-19-2009 10:33 PM
Running New Circuit jasoncw Electrical 11 02-16-2009 01:12 PM
