Running 220V To Dock For Float Lift. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 03:04 PM   #1
running 220V to dock for float lift.
i currently have 220V line run from the main electric panel of the house to the front of the dock with #6 - 4 wires (about a 150 foot run). i need to run another 100 feet to the end of the dock for the new lift and the contractor only needs #10 wires. I don't think i can splice into the smaller wire, but wondered if i should i install a subpanel with cuttoff at the front of the dock and then run the #10 from there to the end?
Uncle Mike is offline   Reply With Quote
Old 09-28-2011, 04:21 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,920
Yes, that's a good solution. You can connect the #6 directly to the #10, as long as the breaker on the circuit is 30A or less. You may want to consider using #8 or #6 all the way down the dock since voltage drop is likely to be an issue on such a long run. A subpanel at the dock would be a good idea anyway, though, because you may want to add other loads like lights and receptacles later.
mpoulton is offline   Reply With Quote
Running 220v Electronics on 120V Outlet? hellfire Electrical 42 01-14-2014 08:59 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 10:46 PM
Running electrical out to the garage... HomeBrewJeff Electrical 2 05-21-2009 09:59 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
