Running 220 To Garage. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 08:09 PM   #1
Running 220 to garage.
Ok, I'm new here. And I'm a rookie with electrical. Planning on running new wiring to my detached garage, and I would like to run 220 along with the regular wiring for future use(Heater, welder, etc) but I'm not sure which size to go with. Not sure if theres a "standard" size 220 to run. Sorry if this is too vague of a question, any suggestions are appreciated.
JonnyPaste is offline   Reply With Quote
Old 05-29-2013, 08:18 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
You can only run one circuit to the garage.
You need to do a load calculation to determine what size circuit you need.
Heat? What size?
Tools?
What kind?
Once you figure that out, then you can determine what size circuit.
jbfan is online now   Reply With Quote
Old 05-29-2013, 08:27 PM   #3
Ok, so I have to run 220 and then somehow split of of that for the 110?
I think I need to buy a book on this stuff.. I know how to run wiring for lights, switches and outlets. I've never messed with the breakers.
Old 05-29-2013, 08:41 PM   #4
jbfan's Avatar
Rewards Points: 650
Correct.
You would install a panel(size determined by the load calculation) and run the circuits from there.
Old 05-29-2013, 09:00 PM   #5
Rewards Points: 1,192
What size is your main service panel now? 100 amp sub-panel would be a nice size,but you can only take off 80% of your existing main rating.Do a load calc.
bobelectric is offline   Reply With Quote
Old 05-29-2013, 09:11 PM   #6
Ok, dont laugh, but how do I tell what size my main service panel is?
Old 05-29-2013, 09:18 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The main breaker at the top of or bottom of the panel. Usually 100.
sublime2 is offline   Reply With Quote
Old 05-29-2013, 09:27 PM   #8
Code05's Avatar
Rewards Points: 1,104
Code reference please.
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
mpoulton (05-30-2013), stickboy1375 (05-29-2013)
Old 05-29-2013, 09:28 PM   #9
Oh, yeah mine is 100.
Old 05-29-2013, 09:30 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Seriously, Where does this stuff come from?
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Code05 (05-29-2013), Philly Master (05-30-2013)
Old 05-29-2013, 09:33 PM   #11
Code05's Avatar
Not the NEC.
mm11 (05-30-2013), Philly Master (05-30-2013)
Old 05-29-2013, 09:34 PM   #12
E2 Electrician
Originally Posted by Code05 View Post
Not the NEC.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 05-29-2013, 10:09 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
Ok boys....put away the testosterone.....
Jonny....getting back on topic...I was in your shoes at one point.
100A for a main might be a little on the 'light' side depending on what you have going on in your house....if everything is gas except for your A/C, then I think you will be fine as long as your not trying to run everything at once.
So....you want 220 Vac in the garage (it really is 240, but don't worry...a lot of people call it 220, 221...what ever it takes)
That 240 Vac feed will actually be 2 120 Vac lines with a neutral and ground....
So...in your main panel your going to have a double breaker...in your case I'm thinking 30A would be enough....without starving your house.
In your garage your going to install a small sub-panel.
Something like this...
It will give you both 240 and 120 Vac capability.
Next, your going to run conduit from your main panel to the garage....I would NOT go under 1"....3/4" would be enough....but conduit is cheap and it's a lot easier to pull wire through larger conduit.
You will then pull 4 wires (I would suggest 10Awg THHN/THWN stranded) from the main to the sub panel. 2 Will be black...1 white and one ground.
The 2 blacks connect to the 30A breaker in your main panel. The white to the neutral buss and the ground to the ground bar in the sub.
In that sub....your neutral buss and ground buss are NOT connected together.
Next...you will sink 2 8' long 1/2 copper ground rods in the ground near the garage. They need to be at least 6' apart and can be below ground. You install a clamp on the end of the ground rod and connect a #4 (or #6 depending on the codes in your area) copper wire to the 1st ground rod...then to the second and then to your sub panel.
Yes...I know the next question....why do you need ground rods at the garage when your also connecting the ground from the main panel.
Because the NEC says you will. I won't go into detail on 1 ground rod vs 2.....long discussion.
You now have both 240 and 120 available for your garage.
Yes, you are limited to 30a...but understand that if your using just 120Vac...well...you have up to 30a on each leg...potentially 60a at 120vac. If you have a 240vac load such as a compressor...then the 120vac available goes done. In my case, my compressor pulls about 7A....since I have a 50A feed...I still have 43A on each leg...potentially. In the real world, about the most load you would have would be a compressor or welder and some lights....add a man cave and all bets are off.
One last thing....pull permits. It's not that expensive....and you will be glad later on.
Good luck and welcome to DIY....
BTW....if you want to see my setup...click on the link in my signature.
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
getfamiliar (06-01-2013), JonnyPaste (05-30-2013), tylernt (05-30-2013)
Old 05-30-2013, 06:40 AM   #14
Rewards Points: 1,548
If you are thinking of heavy current draw tools including welders, and electric heat, I suggest running #6 gauge conductors, which allows you two 60 amp allotments of 120 (110) volt power or one 60 amp allotment of 240 (220) volt power, or some (any combination) of each. You don't have to install all of the other parts immediately, for example you can connect it to a 20 amp breaker pair at the house panel and not have to install the subpanel in the garage yet.
Use the same wire size rules for 240 volts as for 120 volts, for example 12 gauge for 20 amps.
The Following User Says Thank You to AllanJ For This Useful Post:
JonnyPaste (05-31-2013)
Old 05-30-2013, 08:19 AM   #15
JW
mm11's Avatar
Rewards Points: 622
The largest conductor required for the grounding electrode conductor (going to the ground rods) is a #6 Cu.
Make sure the ends of the ground rods are driven below grade.
mm11 is offline   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
Two 20amp curcuits running from House panel to detached garage ChesterT Electrical 10 10-10-2012 05:54 PM
Proper conduit for running wire in garage? mrrr0809 Electrical 5 08-05-2012 04:55 PM
running power to detached garage Roundeye Electrical 10 11-30-2011 09:05 AM
Water running from Driveway into Garage. CAD Building & Construction 5 06-17-2010 07:30 PM
running wire to detached garage amakarevic Electrical 2 02-28-2008 02:17 PM
