I am adding 3 new receps to my garage. I am also running wire for a 230 volt a/c which is all the way around the room from the electrical panel...
I have carefully cut and removed bottom portions of the sheetrock to allow access to the studs so I can thread the wire around the room.
Is it ok to run both wires through the same holes right next to each other?
I have drilled 13/16 holes to accommodate both but got to thinking that this may be a no-no:no:
Any advice on this matter?
Jeff
Jeff
