Running 12-2 Romex In A 2x2 Frame - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 06:21 PM   #1
Rewards Points: 105
Running 12-2 Romex in a 2x2 frame
I am finishing a basement and I want to install an outlet in a wall that has 2x2 framework against the concrete block foundation wall. The plan I have is to make a notch in the vertical studs to run the 12-2 romex cable through and use a steel plate over the notches. The rest of the cable will be secured against the block with fasteners screwed into the block. The cable will be at least 1-1/4" from the top or bottom plate and when it runs vertically down to the outlet box. Is this a valid interretation of the NEC section 300.4(D) where it states that all cable must be 1-1/4" from any surface of a framework member or it must have portection?
wvphysics is offline   Reply With Quote
Old 01-01-2010, 06:49 PM   #2
joed's Avatar
Rewards Points: 13,718
Nail plate is needed but fastening to the concrete is not. You only need fasteners every 4 feet. The studs count as fasteners.
Old 01-02-2010, 06:02 AM   #3
Remodeling Contractor
the nail plate is only needed when the wire is drilled through the studs
Old 01-02-2010, 06:05 AM   #4
Master Electrician
JohnJ0906's Avatar
They are required when the studs are notched, as the OP is planning to do. 300.4(A)(2)
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-02-2010, 06:08 AM   #5
Master Electrician
JohnJ0906's Avatar
You can secure directly to the 2x2s, as long as you are 1" from any edge that screws or nails are likely to penetrate- i.e., the face of the stud.
John from Baltimore
One Day at a Time
Old 01-02-2010, 06:09 AM   #6
Okay.. same thing. Except you should not notch the stud anyway. When going perpendicular to a framing member and less then 1 1/4" from the finishing edge of that member a nail plate is to be used.
Old 01-02-2010, 06:10 AM   #7
Master Electrician
JohnJ0906's Avatar
Why not? That's almost certainly not a load bearing wall.
John from Baltimore
One Day at a Time
Running romex along a wall in a closet Red Squirrel Electrical 16 10-02-2009 08:44 PM
question about running romex in attic ceiling jayp Electrical 5 03-20-2009 01:06 PM
Running Romex Bocolo Electrical 6 02-20-2009 09:58 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 04:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
