Running 12/2 Nmb Wire In An Old Home - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 02:50 AM   #1
Necrosis's Avatar
Question
Running 12/2 nmb wire in an old home
My Outside outlet's hot wire is dead. I need to replace the wire(s). My Question is, How do u run new wire w/o having to repair/replace Drywall? I'm not trying to be...too lazy, just wanna save $$$ on replacing the wires.
20 amp circuit breaker 12-2 nmb 20 amp outlet.
I literally just need to go up, along the Ceiling and down to the Circuit Box. My greatest issue is that, my Ceiling is the Floor from Upstairs... There really is no "crawl space"...
Necrosis is offline   Reply With Quote
Old 07-08-2013, 11:11 AM   #2
joed's Avatar
Rewards Points: 13,766
You will need to cut holes at the floor to ceiling transition. If you are lucky the floor joist run in the direction the cable needs to be fed. Otherwise you will need holes so can drill each joist.
Old 07-08-2013, 11:35 AM   #3
MarginallyQualified
Rewards Points: 2,464
Do you KNOW where this outlet is fed from?
Is that outlet ALSO dead?
Old 07-08-2013, 12:54 PM   #4
Licensed Pro
Wire doesn't just go bad. Chances are you have a GFCI that is tripped or a loose wire at another receptacle or light switch (or fixture).
Old 07-09-2013, 02:00 PM   #5
Necrosis's Avatar
I know what wire it is, where it's fed from, and the out let is new. Circuit breaker is also functional...
Old 07-09-2013, 03:38 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
And_?
Old 07-10-2013, 10:36 AM   #7
Necrosis's Avatar
Sorry, but simply writing "And?" w/ no actual question is just rude. However, house Helper, you were Right about the Switch, I checked everything throughout my house and fund the bathroom outlet had tripped! I just pressed reset and the power came back to the outside outlet. Thank you for your help!
Sincerely Necro
The Following User Says Thank You to Necrosis For This Useful Post:
HouseHelper (07-10-2013)
Old 07-10-2013, 11:07 AM   #8
concretemasonry's Avatar
Rewards Points: 2,654
Necrosis -
You probably did not notice that you did not answer an earlier question referring to a GFCI or did not realize that it is much different than a "breaker" that is in the main box supplying power to the circuits. Because of that there was little to do to help you. That is common problem with a "newbie".
A switch could have been fed off of a GFCI that opens a new can of worms.
Dick
concretemasonry is online now   Reply With Quote
Old 07-10-2013, 12:07 PM   #9
Necrosis's Avatar
concretemasonry I over looked the GCFI because It shouldn't have been connected to the outside outlet. who ever did the electrical system in this house was retarded. Calling me a noob and dick is completely uncalled for. you have been reported. Do not post on this thread again.
Old 07-10-2013, 12:19 PM   #10
JW
mm11's Avatar
Rewards Points: 622
I may be incorrect, but I'm guessing that 'concretemasonry' is named Richard, and goes by that nickname of Dick. I don't think he called you a dick; he merely signed off on his post with his name- Dick.
mm11 is offline   Reply With Quote
The Following 5 Users Say Thank You to mm11 For This Useful Post:
concretemasonry (07-10-2013), frenchelectrican (07-10-2013), HouseHelper (07-10-2013), Kyle_in_rure (07-22-2013), Philly Master (07-10-2013)
Old 07-10-2013, 12:38 PM   #11
" Euro " electrician
frenchelectrican's Avatar
Sincerely Necro
Necrosis.,
Let you know that it was common in older code edition to have a single GFCI to protect bathroom , outdoor receptale plus garage recepectale even in some of the kitchen receptale with single GFCI receptale I know it was common many years ago but that is no longer legit per modern NEC code requirement.
That time many years ago the GFCI was pretty expensive item so they try to keep the cost down now with modern day the GFCI receptale is much cheaper than GFCI breakers so it become normal around in most places.
As I posted above comment whomever ran the wiring arrangment for that era is correct and it was NOT retarded for that era ( late 60's to mid 80's ) then when get to more modern era that pretty much end of that route.
So when that place get rewired in that time era it will follow the latest code that time now let fast foward to current time era. We do know that is no longer the case due the bathroom will required it own circuit and the kitchen will required 2 SABC ( small appalince branch circuit ) the garage will gernally it own circuit. but note this part some are it is common have the outdoor recepales tied to the garage receptale but some area not so it will be it own circuit as well.
As far for calling anyone noob I been called that before few time but afterwhile it will go away I have been called worst than that.
I have one freind I know his real name is Richard but also called Dick which it is a common nickname I know some peoples feel insluted with that so some will just drop the dick word and replace with Rich or Richard but it pretty much up to them what they want to be called.
We do try to help many peoples in here much as possible.
Merci.,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
MTN REMODEL LLC (07-12-2013)
Old 07-10-2013, 12:40 PM   #12
Necrosis -
Also I did not call you a "noob". If you read closer you are classified as a "Newbie" by the site according to your experience and/or amount of exposure.
You might have earlier noted that you eliminated a GFCI in addition to just a "breaker".
I don't think you own the tread you created to get feedback and cannot limit anything.
DICK
Old 07-22-2013, 06:08 AM   #13
Rewards Points: 1,989
Certain " plugs " are required to be protected by GFCI devices . Bathroom and out side plugs are on that list ( among others ) .
It is indeed common for plugs to be wired " down stream " of a GFCI plug , to receive the required protection .
What the OP described is not that unusual . It is one of the first things I look for , when a plug is dead .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 07-22-2013, 06:40 AM   #14
PoleCat's Avatar
Rewards Points: 1,652
................but ya dosen't havta call me Mr. Johnson.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 2 wire homerun splicing with new 12/2? buckman Electrical 1 09-22-2011 08:29 AM
Running wire jackal24 Electrical 5 05-10-2011 07:33 PM
Wire Choice 12/2 or 14/2 Pentium Electrical 13 05-05-2011 03:33 PM
What size wire to use running underground ms66cadillac Electrical 21 01-13-2011 11:14 AM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
