Run Wire From Generator To Play Area - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 10:12 PM   #1
Run wire from Generator to play area
I am looking to set up a country play area and need a bit of advice. I would like to bury 12-2 indoor house wire inside schedule 40 PVC for a distance of 200'.
I would set up a receptacle on one end and plug my generator on the other end. This would allow me to place the generator far enough away for noise not to be an issue and still have power for five to ten 60 watt lights, radio, and some string lights (about 2 amps worth).
The wire and pvc are stuff I have from some demo and auction purchases so i have minimal amount invested in this set up.
The Generator is 3000 watts.
does this sound like it would work or am I nuts.
john
jfiedler is offline   Reply With Quote
Old 06-05-2012, 10:15 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Romex (indoor house wire) is not rated to be in wet locations. Buried pipe is considered a wet location. So, that part of your plan would fail.
Old 06-05-2012, 10:25 PM   #3
Idiot Emeritus
Rewards Points: 1,492
As noted, indoor house wire cannot be used outdoors for any reason.
You can use type THWN in the conduit, or even type UF cable, but not type NM.
Also, I would use a GFI receptacle at the playground.
micromind is offline   Reply With Quote
Old 06-05-2012, 10:42 PM   #4
Sounds like I need to get some other wire and save what I have for another project.
By the way congrats on what looks like a big Walker win.
The Following User Says Thank You to jfiedler For This Useful Post:
mpoulton (06-05-2012)
Old 06-05-2012, 10:43 PM   #5
Thanks Micro. Was planning on GFi Rec.
Old 06-05-2012, 10:46 PM   #6
k_buz's Avatar
I'm not going to say anything until 90% of the results are in.
Backyard Play Area for Kids sippinjoes Landscaping & Lawn Care 8 06-30-2011 10:29 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
