Run Wire To Breezeway Through Brick And Up Brick Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2010, 08:18 AM   #1
Rewards Points: 28
Run wire to Breezeway through brick and up brick wall
I need to run wire from basement to attached breezeway to add a ceiling light and an outlet -15 amp circuit. It will be going through brick (about 1 foot from floor in breezeway) and up brick wall to switch box. Then continue up to 10 ft high ceiling which is plywood. I know I need conduit going through brick. Steel or PVC? Does the conduit go into the back of a mounted box at the hole and then another run straight up to switch and another up to ceiling? Can I use surface mount raceway and boxes which would lookk better, instead of conduit up the brick wall? If so, how do I transition?
Right now there is grey romex going through brick without conduit into the back of a metal surface mount. Then there is a piece of 8 ft conduit going up brick wall and the grey romex is coming out which is stapled to the ceiling.
wad2k is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Garage brick wall repair TANME General DIY Discussions 2 02-04-2010 06:19 AM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 05:57 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 02:45 PM
