Run Romex Through Or Around A Receptacle Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 09:12 AM   #1
Run romex through or around a receptacle box?
I'm installing a microwave in a wall cabinet in the kitchen. Below the cabinet will be a counter receptacle on a different circuit. The microwave and counter box will be on the same stud. How am I supposed to run the romex for the lower box? Should I go through the box, run a loop around the box, or run the wire on the other stud and then cross back over below the upper box?
I can't seem to find this info anywhere!
OmegaWS6 is offline   Reply With Quote
Old 12-05-2012, 09:36 AM   #2
Love for Construction
<*(((><'s Avatar
Don't go in the box if there is no reason to, as you will complicate things having to wire the grounds together being that they are two different circuits.
Just have the wire go around the box and ensure that it is stapled to the stud to secure it.
-luke-
<*(((>< is offline   Reply With Quote
Old 12-05-2012, 12:38 PM   #3
joed's Avatar
Rewards Points: 12,862
You could go through the stud, around the box on the opposite side of the stud and come back through the stud again if the box has to be on the same side. Or just go down the opposite side of the stud and come through above the lower box.
Old 12-05-2012, 12:49 PM   #4
I am shying away from going through the box. Ill loop it around the box and see how that goes. I would rather not drill more holes in the studs, I've run out of nail plates twice now!
My rough inspection is tomorrow, fingers crossed.
Old 12-12-2012, 12:21 PM   #5
Soooo... I passed!
The guy was only an hour and a half late. We were #21 and last of his stops for the day. He didn't say boo about anything except for me jumping the gun and installing the high hats. He complained that he couldn't see the wire for them hanging out the ceiling hole. My girlfriend offered to show him the attic where the connections could be seen, but he declined (shrug). I'm shocked it took so little time and he was gone.
Just need to install the hood vent duct now and then drywall can go up! Btw, does anyone know of a clean/nice product or trim piece to install a vent cap onto? Arlington make a fantastic vinyl siding plate for outlets and lights but nothing I can work with to install a 6" cap.
Old 12-12-2012, 08:23 PM   #6
"I'm shocked it took so little time and he was gone."
Funny because I say the same, not much of an inspection.
Here and gone that fast and passed!
Hardway is offline   Reply With Quote
Old 12-12-2012, 08:25 PM   #7
Licensed electrician
Rewards Points: 1,612
See if the Arlington MM10 would work for you.
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
romex connection to receptacle apshirm Electrical 3 09-15-2011 02:28 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 08:32 AM
receptacle: 1 romex in 2 out? DIYGST Electrical 4 01-28-2010 04:35 PM
how to wire romex to 2 3 ways to a half hot receptacle smoothinstall Electrical 3 11-30-2008 10:56 PM
