Run Outdoor Conduit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 08:14 PM   #1
run outdoor conduit question
Hey im new here so pardon me for any errors but i'm trying to run 12/2 conduit from my basement(there is an unused dedicated 20amp circuit for washer/ dryer) to my detached garage(50' from the basement receptacle) and i plan on running the conduit strapped alongside the house without having to dig due to concrete driveway. I don't know which conduit to use and plan on putting an outdoor receptacle on the way to the garage as well...the garage will ultimately have only one receptacle and a light. Can someone please tell me if this sounds do-able.
nycjas26 is offline   Reply With Quote
Old 07-16-2010, 08:34 PM   #2
dSilanskas's Avatar
If your going to run the feeds along side of your house you should run it in PVC.
dSilanskas is offline   Reply With Quote
Old 07-16-2010, 09:17 PM   #3
Laundry area also requires a dedicated 20a circuit
That circuit can't feed anything outside of the laundry area
Old 07-16-2010, 10:17 PM   #4
Licensed electrician
Rewards Points: 1,884
Conduit is the tube like pipe that individual conductors are installed in. Cables are commonly labeled 12-2.
Type NM-B cable cannot be used on the exterior of the house, even if in conduit.
Tags
conduit , detached , garage , gfci , outdoor
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
