Old 12-28-2010, 07:12 PM   #1
Run 12/3 but only use 2 wires?
I'm curious if it is okay (within code) to run 12/3 but only use one hot, the neutral and ground and not use the red?
monkeystomach is offline   Reply With Quote
Old 12-28-2010, 07:15 PM   #2
joed's Avatar
No problem with that.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-28-2010, 07:26 PM   #3
Great! Good to know.
Old 12-28-2010, 07:27 PM   #4
If the red is at any point connected to the hot, you need to cap off the other end.
clashley is offline   Reply With Quote
Old 12-28-2010, 08:03 PM   #5
Do it right.
Don't snip the red to where you can't use it. You never know when you may need it in the future.
SubSailor is offline   Reply With Quote
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 12:20 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 10:24 AM
