Run 12/3 but only use 2 wires?
I'm curious if it is okay (within code) to run 12/3 but only use one hot, the neutral and ground and not use the red?
Thanks |
No problem with that.
Great! Good to know.
Thanks |
If the red is at any point connected to the hot, you need to cap off the other end. |
Don't snip the red to where you can't use it. You never know when you may need it in the future.
| All times are GMT -4. The time now is 12:34 AM. |
