Rules For Wiring Inside The Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2008, 01:18 AM   #1
Rules for wiring inside the attic
Do all multi wire connections inside the attic need to be inside a metal box?
Does all wiring have to follow the framing or can I make short cuts?
Any other golden rules I should follow?
amdspitfire is offline   Reply With Quote
Old 04-09-2008, 02:21 AM   #2
Lehigh Valley PA
From what I understand ALL splices or connections must be in an approved box which also needs to be accessible at all times. Meaning they cannot be covered over with any wood, drywall or such materials.
Also I believe where and how it is run in the attic depends on what access there is to the attic. Is it a walk-up, or is there just an access space you have to crawl through?
I'm sure you'll get many responses from the great electricians here shortly as well.
Nhrafan is offline   Reply With Quote
Old 04-09-2008, 05:08 AM   #3
When is fishing season?
CowboyAndy's Avatar
Yes, ANY AND ALL splices for interior wiring MUST be made in a proper junction box that remains accessable at all times.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-09-2008, 06:54 PM   #4
It's just an access space.
Old 04-09-2008, 08:48 PM   #5
Wiring in the attic is allowed to be non-metallic cable (NM cable), assuming that NM cable is allowed in your area. It is allowed in most areas of the US. The fact that the attic gets hot (or cold) does not matter. However, it is imnportant that the cable (actually the individuals wires that make up the cable) be the correct gage for the circuit. A 20 amp circuit requires 12 gage wire, a 15 amp circuit requires 14 gage wire.
“An intellect rivaled only by garden tools”
Electrician FAQ - Electrician Apprentices
GeryFajardo is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Attic Insulation jim_arnau Building & Construction 13 11-07-2007 08:59 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 04:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
