-   -   Rules for wiring inside the attic (http://www.diychatroom.com/f18/rules-wiring-inside-attic-19688/)
amdspitfire 04-09-2008 01:18 AM
Do all multi wire connections inside the attic need to be inside a metal box?
Does all wiring have to follow the framing or can I make short cuts?
Any other golden rules I should follow?
Nhrafan 04-09-2008 02:21 AM
From what I understand ALL splices or connections must be in an approved box which also needs to be accessible at all times. Meaning they cannot be covered over with any wood, drywall or such materials.
Also I believe where and how it is run in the attic depends on what access there is to the attic. Is it a walk-up, or is there just an access space you have to crawl through?
I'm sure you'll get many responses from the great electricians here shortly as well.
CowboyAndy 04-09-2008 05:08 AM
Yes, ANY AND ALL splices for interior wiring MUST be made in a proper junction box that remains accessable at all times.
amdspitfire 04-09-2008 06:54 PM
It's just an access space.
GeryFajardo 04-09-2008 08:48 PM
Wiring in the attic is allowed to be non-metallic cable (NM cable), assuming that NM cable is allowed in your area. It is allowed in most areas of the US. The fact that the attic gets hot (or cold) does not matter. However, it is imnportant that the cable (actually the individuals wires that make up the cable) be the correct gage for the circuit. A 20 amp circuit requires 12 gage wire, a 15 amp circuit requires 14 gage wire. :)
“An intellect rivaled only by garden tools”
Electrician FAQ - Electrician Apprentices
