Rule Of Thumb On Recessed Light Placement Relative To Countertop? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 12:19 PM   #1
Rule of thumb on recessed light placement relative to countertop?
I'm set to install seven or eight 4" recessed light cans in my kitchen. Most of them will follow the layout of the countertops. Is there any rule of thumb to follow in terms of placement relative to the edge of the countertops? I assume that too close to the upper cabinets would be bad, but then you don't want them so far off that standing in front of the counter creates a shadow on the work surface.
Any thoughts or recommendations?
TomServo is offline   Reply With Quote
Old 05-14-2010, 12:51 PM   #2
I've heard that they should be centered on the edge of your counter top.
bsperr is offline   Reply With Quote
Old 05-14-2010, 01:07 PM   #3
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
You answered your own question and answered it right! Your assumptions are correct; not to close to the top cabinet and not behind where you would stand at the counter but as close to middle ground as you can get between those 2 points!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 05-14-2010, 06:26 PM   #4
I've seen them within the 2' edge of the counter below. It gave a unique splash of light off the wall cabinets and can look very nice depending on your cabinets. I've also see them at 30" out or 6" beyond the countertop edge below with threw light towards the worksurface and face of the cabinets below give a little fuller lighting down to your feet. I kind of like this approach since you dont throw shadows across the edge of the countertop toward your feet below.
Penguinfan is offline   Reply With Quote
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 09:29 AM
Rule of thumb...knobs or pulls and placement? Kelly R. Remodeling 4 02-11-2009 04:50 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
Recessed Outdoor light fixture Scott_K Electrical 6 04-05-2005 04:53 PM
