Rubber Coated Cable Clamps In Main Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 06:23 PM   #1
Rubber coated cable clamps in main panel?
Can these rubber coated cable clamps be used to hold back main feeder cable in a electrical panel and pass code?
http://andersonpower.com.au/store/im...teelRubber.jpg
rodm1 is offline   Reply With Quote
Old 01-13-2011, 08:06 PM   #2
Electrical Supplier
Rewards Points: 150
I would say no as you would have to drill into the panel to secure them right?
Any modification to the panels, either physical or electrical voids the UL listing and could be grounds to fail an inspection.
Why are you doing this?
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-13-2011, 08:28 PM   #3
Master Electrician
Rewards Points: 3,962
Ever make a knockout in a panel????????????
brric is online now   Reply With Quote
Old 01-13-2011, 08:44 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
LOL. I know, right.
Old 01-13-2011, 08:45 PM   #5
rodm1, those are called adel clamps, and no, they are not typically used to hold the cable or wires in a panel. Tie wraps would be more appropriate.
Old 01-14-2011, 04:36 AM   #6
Scared Electrician
Saturday Cowboy's Avatar
Seconded
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-14-2011, 04:45 AM   #7
My electrician ran a panel screw into the main feed! I would like to make it hack proof. I could tie wrap to the lug wire coming after the main breaker.
Right middle screw where tape is
Old 01-14-2011, 05:11 AM   #8
Scared Electrician
well the correct screws without points would go a long way to helping. Usually with such large wire you can bend it and it will retain its shape, but for more control of wiring in panels (because of future need to move them) wire ties are used by electricians. they are cheap and easy to cut out if needed.
Old 01-14-2011, 05:22 AM   #9
TOO LATE!
WTH is with that homemade feed-through lug setup???
Is this guy for real?
Old 01-14-2011, 06:22 AM   #10
Rewards Points: 764
Originally Posted by Speedy Petey View Post
TOO LATE!
Pete, I saw the modified sub-feed before I got down to your post. Agree. What a hack job.
FWIW, I did install a true QO sub-feed loadcenter a few weeks ago. Had to special order it. They are pretty common in panelboards and pretty rare in loadcenters.
Mark
busman is offline   Reply With Quote
Old 01-14-2011, 07:49 AM   #11
Household Handyman
Rewards Points: 1,408
Saw the "screw into feed line with tape" on a new home construction about a year ago. Electrical inspector caught it, made the electricians remove the entire panel and feed wires back to the meter can. They were not happy to say the least. The inspector cited the use of electrical tape on main feed wire, and "damaged panel" for the reason to remove all of this. I'm thinking it was a more personal thing.
Old 01-14-2011, 07:58 AM   #12
Licensed electrician
Rewards Points: 1,876
Now he can sell the homeowner a subpanel to make up for all the spaces that can't be used due to the feed-thru arrangement.
Speedy Petey (01-14-2011)
Old 01-14-2011, 08:36 AM   #13
Rewards Points: 764
BTW, nice debris and foreign matter all over the bus.
Old 01-14-2011, 08:43 AM   #14
Rewards Points: 6,652
No. The are used to secure jacketed cables. The Military uses them for the Radio Wave Guides, same with the Cellular Industry, and securing Telco cables.
Old 01-14-2011, 08:47 AM   #15
Of course, it is always fun replacing a Bus Bar when it melts from not getting Shore power in sync with Shipboard power systems. Never thought that we could melt one, but we did it in France. Had to run on Ship's power the whole 3 weeks we were tied to the dock. Home owners would not know what to do with that one, and would probably just run down to the local home center and buy what ever wire the store monkey told them would work.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 06:55 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Main panel design question amakarevic Electrical 13 06-04-2007 04:35 AM
