Row Of Ungrounded Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2012, 12:48 PM   #1
Row of ungrounded outlets
Hey everyone-
I just bought a house. While most of the electrical is good in the house, my inspector found that every plug outlet along one single shared wall are not grounded (according to his tester).
If I open up the outlet covers, the ground wire is connected in all of them. Is there something that would cause an entire line of outlets to not be grounded? All of the electrical in the house is brand new. I'm not sure if its a factor, but I opened up an old outlet box that was covered shut when they put in new wiring. The wires weren't capped or anything... Just sitting open in the box. I dont have a volt meter so I havent had a chance to test whether they are active. Maybe some old uncapped wiring still on the same breaker could be causing a problem?
Steve
WVAmature is offline   Reply With Quote
Old 12-01-2012, 02:33 PM   #2
Civil Engineer
Rewards Points: 4,764
You can purchase your own outlet tester for under $10. They are quite useful, typically they have three lights, and will show improper conditions such as reversed neutral and hot, lack of ground, etc. As to why a whole string of outlets would show no ground, it is possible that the outlets are daisy chained together, and the ground to the first outlet in the chain is bad. This could occur if the ground wire to the first outlet was damaged or severed, or possibly not installed.
You can purchase a multimeter for less than $50 that will prove to be very useful in determining if wires are live, if grounds are good, and a whole host of other issues. Worth the purchase if you plan to do any home wiring.
Old 12-01-2012, 04:32 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Try and determine where to circuit is fed from. Start checking the boxes on either side closest to the receptacles.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Ungrounded outlets in a student room [Ontario] Guitarfreak Electrical 10 09-14-2012 06:47 PM
Ungrounded outlets crescere Electrical 18 08-29-2012 05:27 PM
Best way to upgrade ungrounded outlets to grounded? mikemcd Electrical 5 09-12-2011 09:58 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Ungrounded outlets white29 Electrical 2 05-31-2010 02:31 PM
