Routing Wires...attic Or Basement? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 01:37 PM   #1
Rewards Points: 105
routing wires...attic or basement?
From my other thread I posted, I am roughing in two new bathrooms and need to run a few new circuits.
This is a 1 story ranch, panel in the basement. All original wiring is run from the basement to the attic, then down to the fixtures. The basement is completely unfinished with easy access.
Is there any reason I should pull my new circuits through the attic where its already 90+ degrees and hard to work in w/ low pitch roof? I think fishing new holes from the basement wouldnt be too hard at all. The only reason I can think of working in the attic is that all other wiring is in the attic already....
thoughts?
redline9k is offline   Reply With Quote
Old 03-07-2011, 01:46 PM   #2
Licensed electrician
Rewards Points: 1,278
I would go with the easiest route. I would much prefer to drill a hole thru the sole plate and run wires standing up compared to stuffed into an attic filled with insulation.
Old 03-07-2011, 02:43 PM   #3
JohnnyD44's Avatar
I agree,
I recently had the same situation on in reverse. Some of my wiring was run through my crawlspace and most of it was run through the attic. I didn't want to be crawling around in the crawl space, so I too chose the easier route and I'm sure my back and knees thanked me!
JohnnyD44 is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
How to run wires through an attic? mopowers Electrical 8 02-27-2010 04:48 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
