Old 06-12-2011, 08:43 AM   #1
Routing romex under joists
I have some wiring in my basement that runs perpendicular to the floor joists overhead. About 8 runs of Romex NM near the foundation wall.
This wiring is stapled to the bottom of each joist, not running through holes in the joists. I don't believe that there is any risk of damage in this area (always subject to opinion of course).
Is this acceptable according to the NEC? 300.4 is not very explicit on this and I don't know of another area where this is mentioned.
Fritz
sonnichs is offline   Reply With Quote
Old 06-12-2011, 08:51 AM   #2
Just call me Andrew
Wiring run in this fashion is supposed to be on running boards. Some type of wood (a 1-by or soemthing similar) is attached to the bottom of the joists, and the wire is attached to the wood. This prevents things like a shop light or clothes hanger from being hung from the wires.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
sonnichs (06-12-2011)
Old 06-12-2011, 09:00 AM   #3
Electrician
SD515's Avatar
334.15/specifically 334.15(C)
Kyle
The Following 2 Users Say Thank You to SD515 For This Useful Post:
secutanudu (06-12-2011), sonnichs (06-12-2011)
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 06:28 PM
Joists, Acoustic Tiles and Romex - is this OK? globus999 Electrical 4 09-08-2010 05:27 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Romex - through or under joists? BimmerRacer Electrical 2 04-21-2009 10:47 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
