Routing Ground Wire From Panel To Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 10:23 AM   #1
Routing ground wire from panel to rod
Hello,
Trying to route my #6 ground wire from the service panel to the two 8-foot ground rods outdoors. How is this normally done? I would rather not drill a hole in the vinyl siding.
thanks!
novaguy is offline   Reply With Quote
Old 01-15-2013, 11:03 AM   #2
Rewards Points: 13,752
Why not run it behind the siding?
Old 01-15-2013, 11:07 AM   #3
Rewards Points: 282
how do the service wires get there?
jcrack_corn is offline   Reply With Quote
Old 01-15-2013, 11:12 AM   #4
Under the siding. Sounds great!
Service comes in underground.
Old 01-15-2013, 03:13 PM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Along the surface of the foundation. If it is subjected to physical damage it needs to be protected.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-15-2013, 04:20 PM   #6
leave it exposed. put it behind the clamps holding the pvc conduit on the service feed. in my area the phone and cable companies hop on to the ground for their use also. years ago i thought i would get smart and put it behind the bricks. the public utility companies looked me up and knocked that in the head. i have heard some areas are requiring them to have their own ground now because of the path a lightening strike will take.
buddy builder is offline   Reply With Quote
Old Cutler Hammer CH12 panel - ground block GroundLoop Electrical 11 02-15-2012 10:19 AM
Running new(up to code) ground wire & protection. MikeSF Electrical 25 07-04-2010 04:33 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
