-   -   Routing ethernet in house (http://www.diychatroom.com/f18/routing-ethernet-house-179562/)
word2yamutha 05-14-2013 12:11 PM
I have a 1 story house with a basement and I'm trying to see what the easiest way to wire cat6 in the house. I looked in the attic and there is blown in insulation so it's hard to tell where the wires are located, but my current telephone line is up their.
I was thinking the basement just because it is cooler and easy to work with. My only concern is making a hole in the drywall and being able to locate it in the basement.
ddawg16 05-14-2013 12:30 PM
I would go basement. In most cases, your outlet for the jack will be close to the floor. If you try to fish from the attic, you may have concerns with fire blocking.....
It's not hard finding the wall. In most cases you can see nails punching through where the bottom plate was nailed.
Cut the hole in there wall where you want the plate to be....then go down below and find the bottom. As long as you are close (as in between studs), you will be ok. If you see daylight after you drill the hole, your in the stud bay....if you see your wife's face...you went through the floor.
mm11 05-14-2013 01:10 PM
Routing through the basement is probably the best way. The easiest way is to cut the hole in the drywall where the data outlet will be, and use a long flex-bit to drill down through the floor. Tape the data cable to the flex-bit with a small piece of wire through the hole on the head of the bit, and then pull the cable out the wall.
http://i01.i.aliimg.com/img/pb/128/8...a_web9_201.jpg
word2yamutha 05-18-2013 10:55 AM
Thanks for the tips. If I do it close to an electrical outlet there wont be any sort of interference correct? Well I was thinking about keeping all of my networking equipment underneath the basement stairs, but I'm not sure if that would be a suitable place for it.
sgip2000 05-18-2013 11:15 AM
Just keep it at least 6 inches from the electrical wiring when possible. If you need to cross electrical, do it at a 90* angle.
word2yamutha 05-19-2013 02:08 PM
How big of a flex bit do I need?
sirsparksalot 05-19-2013 03:14 PM
Looks like that bit is about to come back through the drywall :laughing:
I have never been able to get my flex-bit to work for me; just seems like no way to steady the bit-end enough to cut the hole.
Do these things just not last long enough?
RWolff 05-19-2013 03:21 PM
The basement is a good location for everything if you put it on a shelf, usually it's cooler in the basement which is good for the computers.
My setup involves 4 computers, (2 are never shut down) a router, cable modem, printer, stereo amp and they are all in the basement on a shelf where its cooler, cleaner and out of the way.
The shelf is in the area of the basement below where my desk is in the kitchen, so I didn't need to extend cables much.
user1007 05-19-2013 03:21 PM
What are you using the cat6 or whatever wire for? Won't a secured wireless router work as well as running wire everywhere?
deverson 05-19-2013 04:46 PM
Look for heating ducts, water pipes and anything else that goes through the floor. Measure off of those to find where you want to drill. Just remember, everyone of us that has done this for very long has, or will, drill and miss the wall. It just happens!
If your drill at receptacle height you can use a 18" spade bt with a small, 5/8", bit and that will make it into the basement.
word2yamutha 05-19-2013 08:24 PM
Well I thought about putting all my equipment under the stairs of the basement. Its extremely dusty down there and humid which isn't good for any kind of equipment like that. Im using that cat 6 to terminate into a patch panel then to a switch. I do a lot of streaming and I need gigbit speeds, which wireless can't handle yet. Eventually 4k TV's are going to use more bandwidth so try to future proof that.
gregzoll 05-19-2013 09:03 PM
All of my equipment sits in our basement. It is conditioned like the rest of our house, and stays regularly between 58-68 degrees down there, with anywhere from 46-65% humidity levels. Most dust that falls down through the stairs, is from what is tracked in as you enter.
I actually have just six runs in my network, since the majority of my equipment is wireless. I have three drops for my U-Verse boxes, two drops for the two access points in my house, one access point has a five port switch, since it sits in my entertainment center, then one drop for a IP camera.
If you are pulling coax along with the ethernet, I would go with "Octopus" cable, which would have two Cat-5e & two RG-6 in the cable. Really first off, how many rooms are you planning on wiring, and how many drops per outlet are we talking?
What equipment do you currently have for networking (switches, router, modem), and can you post pictures of your current setup that you have, if in your basement? As for stopping any dust and heat along with humidity into the basement, you really need to seal any gaps around the foundation, where the sill & rim joist meets it, along with insulating the perimeter.
Most people vote to go with XPS foam, I went with R-13, because I still need makeup air in my basement, because of the dryer & water heater down there. You just need to assess your situation before you start with the pulling of any ethernet, then figure out rough estimate of how many feet of cat-5e or cat-6 you will need per drop. I went through 200' for the six drops in my place, when I pulled all new drops, because the original was pulled out of a place that I had, before we moved into this place, and was not meeting the needs for gig speeds.
digitalplumber 05-19-2013 09:55 PM
Better connection, never have to worry about it dropping and or range. In the long run when you can you should always, IMO, use a wired connection.
word2yamutha 05-19-2013 10:15 PM
Well in the basement I only have one outlet, which is on the other side of the house. So I probably won't install in the basement.
I plan on installing in my living room closet because there was an old security system installed so I already have easy wire access and less holes to drill.
vsheetz 05-19-2013 10:48 PM
I have whole house and detached workshop with most everything on wireless. Things not wireless are those co-located with the router and switch. Wireless works great when properly designed.
