Routing DC Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2007, 04:00 PM   #1
Routing DC wiring
Is it possible to route wiring from one battery source to two different lights without putting it in serial connection? It would be great to do a Y-shaped wiring instead of something like P shaped.
Alpha Crow is offline   Reply With Quote
Old 09-27-2007, 04:13 PM   #2
With such low voltage, the resistance of the two lights in series, might be great enough to drop the voltage so far that the lights won't burn. So you can't run a wire from a positive supply, to one terminal of bulb A, then connect the other terminal of that bulb to bulb B, and connect the final terminal of bulb B to the negative supply.
In general low voltage DC circuits are always run Parallel. Run a wire from the positive supply to one terminal of bulb A, and also to a terminal of bulb B. Then run a second wire from the negative supply to the remaining terminal on each bulb.
NateHanson is offline   Reply With Quote
Old 09-27-2007, 04:25 PM   #3
Once fried, twice shy.
elkangorito's Avatar
What is the voltage of the battery & what is the voltage of each light?
Until this information is known, it is impossible to tell how you should wire them.
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
need: "new construction" book on wiring bjherron Electrical 4 09-21-2007 02:23 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
