Routing Coax Through Small Section Of Cold Air Return - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 04:03 PM   #31
gta
Originally Posted by brric View Post
Amen.
It's coax rg6 cable not cat 5.
gta is offline   Reply With Quote
Old 12-19-2012, 05:42 PM   #32
Master Electrician
Rewards Points: 3,678
What's your point?
brric is online now   Reply With Quote
Old 12-19-2012, 08:16 PM   #33
gta
My mistake. I meant to quote k_buz.
Old 12-20-2012, 04:08 AM   #34
gta
One last question.
I know that I'll pass a high voltage line while routing the cable. I read that you should keep low voltage cables at least 1 foot or more away from high voltage cables if running parallel, but that is not possible in my case.
I can however run perpendicular, which is recommended. Should I still try to maintain some space between the high voltage and low voltage cables or can they be touching a bit?
Forced Hot Air Heat - No Cold Air Return DIY12 HVAC 27 10-22-2012 10:29 AM
Cold Air Return Duct in Garage Ceiling (for bedroom above) jbrocious HVAC 8 10-15-2012 05:52 PM
tapping into cold air return Mr Chips HVAC 4 02-24-2011 08:24 AM
question about cold air return locations ponch37300 HVAC 4 01-11-2010 09:56 AM
Weak Cold Air Return sbhcom HVAC 1 12-11-2009 02:14 PM
