Rough In Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 07:33 AM   #1
Rewards Points: 81
Rough in Question
I am drilling 3/4" holes in my 2x4 studs, is there a limit to how many 14-2/14-3/12-2 that I can run through each hole? Obviously size plays a role in that I could probably fit 2 or 3 but curious if there is a rule
Also is there a limit to the amount of 3/4" holes I can drill into a 2x4 or a minimum distance apart? I ask because my home came prewired for home audio and one of of the studs I drilled a total of 4 3/4" holes about 8" apart to run the home audio cable and electrical. In addition I probably need to add another 2 for audio cable going back into that room.
Thanks,
Larry
LarryM is offline   Reply With Quote
Old 05-31-2012, 09:16 AM   #2
Never seen any maximum amount of holes you can drill or number of wires in hole, i always go atleast 2 inches apart and 6 inches between speaker wires and electrical wiring. Maybe someone else has seen it in the code book, but I haven't
electrocution is offline   Reply With Quote
Old 05-31-2012, 10:25 AM   #3
Thread killer
Rewards Points: 272
There are rules but for the life of me, I can't find the links to them
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 05-31-2012, 12:18 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,964
I found this link....seems to be pretty consistant with what my drawings show..
http://www.familyhandyman.com/DIY-Pr...View-All#step1
Just do an internet search on "Notching and Boring"....
Old 05-31-2012, 12:19 PM   #5
Rewards Points: 81
Ok thanks guys, if anyone can find the code I would greatly appreciate it.
The audio cable and electric cable are going to cross at some point, but I'll do my best to minimize them running in parallel
Old 05-31-2012, 12:19 PM   #6
Rewards Points: 81
Nice timing!
Also nice link, I finally figured out what the heck DWV meant when referring to PVC
Old 05-31-2012, 12:25 PM   #7
Rewards Points: 320
Here's the code. You'll have to search through the electrical section, but it shouldn't be too hard to find.
http://publicecodes.citation.com/icod/irc/index.htm
Just make sure I believe the holes have to be at least 1 1/4" from the edge of the stud and you need protector plates on the edge prevent drywall screws (or others) from drilling into the lines.
autx790 is offline   Reply With Quote
Old 05-31-2012, 12:43 PM   #8
JOATMON
ddawg16's Avatar
You have it right on the parallel part....crossing at right angles is not an issue.....and the best way to do it..
rough framing for an exterior door (not prehung) measurement question graysqwrl Building & Construction 5 08-15-2011 08:51 PM
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
Rough Opening issues for interior Pre-hung door get2bill Carpentry 3 04-04-2009 07:27 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
