Rough Plan Design - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 01:36 AM   #16
" Euro " electrician
frenchelectrican's Avatar
I will just suggest to leave the numbers of cans alone and use the multi location dimmer I know they are not that cheap but it will justify the cost so you can use the dimmer at any location where you have three and four ways switches are { if you going with multi location dimmer please pay attetion to the way you bring the cable or conductor to the switch boxes and please try to leave a netural at each switch boxes (It will be required in 2011 NEC code requirment anyway )}
For the bulbs I know you say 75 watts PAR 38 but really I suggest use the 65 watts BR30 bulbs or get one with halogén verison and watch the system wattage total for each dimmers.
For unfinshed room I know you say recessed can but if that going to be a storage room then to play the game in wise way is use the shower trim due that can be a cloth closet and the NEC code do not allow any open indentscent bulbs in cloth closet or storage room if the ceiling hight is semilow { this will be much safer this way anyway}
Just be aware you will need AFCI if your state code do require it and I know you say something about wet bar which I did see the drawing you will need a GFCI receptale for it. Excat details I have to look up to make sure (they are pretty simauir to kitchen useage but not the excat the same )
Merci.
Marc
Old 04-01-2011, 07:33 AM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Merci.
Marc
GFCI protection required for wet-bar receptacles within 6 feet of a sink.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
frenchelectrican (04-03-2011)
garage plan HoweD Building & Construction 7 03-28-2011 08:14 PM
design tall shower front to vent okiegal Plumbing 1 01-06-2011 03:25 PM
Most reasonable house plan design Ronnie71 Building & Construction 3 01-13-2010 09:38 PM
Bathroom Remodel - design questions secutanudu Remodeling 24 01-12-2010 07:39 PM
How to get a rough quote on a basement?? cloudkicker101 Building & Construction 4 04-18-2006 11:48 AM
