Rough In Pigtails - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 06:59 AM   #1
Whatamess
Rough in pigtails
Please help a old man remember. When roughing in light boxes etc. what is the accepted method of signifying the hot wire from the switch. I think it use to be just bend it back or twist a pigtail. Can not remember.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-31-2008, 08:38 AM   #2
The correct method is to wrap it with black electrical tape. I've seen electricians use a black permanent marker to mark them black. I'm not exactly sure what the code book says as I don't have it near me but the inspectors pass it either way here.
KHouse75 is offline   Reply With Quote
Old 08-31-2008, 08:55 AM   #3
Electrician
I wasn't even sure he was talking about a switch leg, but if so, then yes, the white conductor must be re identified.
chris75 is offline   Reply With Quote
Old 08-31-2008, 09:53 AM   #4
Whatamess
What I mean is if you see two black wires in a light box after rough in and drywall is up how do you identify which goes to the switch and which is hot. It use to be common to bend it or strip the end or something that I can not remember. Then who ever comes to install lights,fans etc. knows which is which. The drawing above on the left if you remove the light which black goes to light which to switch. Hope this clears it up.
This getting old s...t sucks. But the alternative is worse.
Old 08-31-2008, 09:56 AM   #5
Electrician
They both go to the switch, no need to identify them, if you had 3 blacks in a box, then I would pigtail the hots together at the rough, so I still only had two wires when I came back. gotta keep it simple.
Old 08-31-2008, 10:18 AM   #6
Whatamess
In the drawing one goes to the light and one to the switch. Take the light away what goes to what?
Old 08-31-2008, 11:12 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
In the rough in of the light box, I would wirenut the grnds, tape the white switch leg with black and wirenut that to the source black. That will leave sw-leg blk and neutral for when the light is installed later. At sw box, tape the white with black and that's it.
I understand your original question about 'bend the wire back, twist a pigtail' etc., but everybody does it different.
Old 08-31-2008, 01:04 PM   #8
Two wires, two terminals. It doesn't matter which goes where. The switch conects the two wires or disconnects them.
220/221 is offline   Reply With Quote
Old 08-31-2008, 05:21 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
except for us anal folks that install the hotwire on the top screw terminal.
there is no code rquirement to indicate the hot or switchleg. Many in may area curl the switchleg or put a piece of tape on the hotleg, or is it the other way around? It is a matter of personal preference and i have seen many methods employed. If it makes a diff, all that matters is the trim guy knows how they are indicated.
pigtails in Canada rtoni Electrical 13 07-24-2008 11:02 AM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 07:45 PM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 12:24 PM
Are fascia boards rough carpentry? Paul58 Building & Construction 10 04-19-2006 10:18 PM
