Old 04-09-2010, 08:56 PM   #1
rough inspection grounds
Getting ready for rough inspection. The inspector wants to see wires stripped and grounds connected. Trying to determine exactly what I should do. For the outlets that have two wires coming in, I am stripping the wires, twisting the grounds tight and then crimping the grounds together. Then I am clipping one of the grounds after the twist. Is there any difference for three cables? do I twist all three, crimp, and then cut two, leaving one wire past the crimp/twist?
bfan781 is offline   Reply With Quote
Old 04-09-2010, 09:36 PM   #2
Master Electrician
Yes if that is what he requires. Don't know where you are but in our area inspectors want switch boxes made up, metallic boxes grounded, etc. We've never had to make up equipment grounds on the rough for receps. Different inspectors different requirements.
brric is online now   Reply With Quote
Old 04-10-2010, 09:21 AM   #3
If you use crimps and you would need two pigtails, then two long ends can continue uncut past the crimp. If you have three incoming ground wires and need three pigtails, then all three ground ends continue past the crimp.
If you use wire nuts, at most one end can go past the wire nut and that is only if the wire nut has a hole in the small end. The other needed pigtails have to be separate 6" lengths, coming out the large end.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 04-10-2010, 09:56 AM   #4
Master Electrician
The only wire that is a 'pigtail' is the wire or wires extending to the device(s), e.i. switch , recep, or fixture.
For instance, in a 3 gang switch box, all of the grounding wires are twisted, crimped, wire nutted whatever along with 3 pigtails which are later connected to the switches.
Old 04-10-2010, 05:56 PM   #5
Little confused, so for the grounds, the boxes that have two wires going in, I am twisting, crimping and cutting one after the crimp. The one I didnt cut will go to the device. If I have three wires going in, should I twist, crimp, and cut two so only one extends past the crimp? Or should I just cut one and have two extend past the crimp, which will be pigtailed and go to the switch, recept. etc?
This may be a stupid question, but still learning. If I have a box that has two separte circuits in it, one 15, one 20 amp are those grounds connected twisted together or do you do them each to there own twist/crimp?
Old 04-10-2010, 06:41 PM   #6
Electrical Contractor
You leave any excess wires after the crimp to the number of devices in the box.
If you have three wires and only one device, you cut two.
If you have two wires and 2 devices, then you cut none, and so forth and so on.
Yes all grounds connect together.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-10-2010, 07:25 PM   #7
All grounds from all cables are connected together in a box. But if two hot feed cables enter a box, the neutrals are kept separate (separate wire nuts), each feed neutral is connected just to the neutrals of the loads it serves.
Old 04-12-2010, 04:39 PM   #8
Is there a good way to twist three or four grounds together?
gregt848 is offline   Reply With Quote
Old 04-12-2010, 05:36 PM   #9
Practice and a good pair of lineman's pliers!
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 05:39 PM
Rough Electrical Inspection gregt848 Electrical 11 03-11-2010 09:36 AM
Passed my rough inspection, now what? theatretch85 Electrical 12 05-03-2009 03:11 AM
Rough electrical inspection - passed today! THANKS!!! vsheetz Electrical 4 02-06-2009 11:42 PM
Passed rough inspection, thank you! mt232 Electrical 1 06-13-2007 04:27 PM
