Rough In Inspection - Existing Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 06:56 AM   #1
Rewards Points: 81
I am almost complete with my rough in and I plan to use an existing circuit for lighting. The existing circuit powers 5 lights in my basement. I am removing these 5 lights and replacing with 13 lights. I have run all new wire to the 13 lights and 7 switches (3 normal, 4 3-way)
My problem is how do I complete a rough in without having my existing branch connected to the new lights? If I turn off the circuit and wire up the boxes I have no light in the basement so it would be difficult to inspect or for me to work in.
I assume I can't hook up the circuit and power all my lights can I?
LarryM is offline   Reply With Quote
Old 06-07-2012, 07:06 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You don't want the switches installed at rough inspection. The inspector will want to see the connections/splices inside the boxes. There are other reasons you won't want the switches in as well. First, there is a good chance of them getting all gooped up with paint or drywall mud. And second, if the switches are installed you will end up cutting the holes (for the switch boxes) too large
Just leave the lights disconnected and use some plug in type light.
Old 06-07-2012, 07:09 AM   #3
Rewards Points: 81
Thanks!
I was afraid of that answer
Is there a meter to measure existing amp load on a given circuit? nexusteve Electrical 12 09-27-2011 02:22 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Acceptable to run new 120v circuit in existing conduit carrying 240v? TomServo Electrical 4 10-22-2009 06:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Passed rough inspection, thank you! mt232 Electrical 1 06-13-2007 04:27 PM
